Please help might need guidance. Minime
Old Dec 15, 2011 | 02:26 PM
robertjegan's Avatar
Default Please help might need guidance. Minime
I have a d15b7 block with a d16y8 head/manifold/etc
I just read somewhere about the knock sensor. I didn't have a hole to install or clip it on the b7 block so I left it out... How big of an issue is this and will I need to drill and tap a hole and have this working.
I also believe my motor/ecu combo is from a obd2 automatic d16y8. I know this because there is some custom nonsense wiring going on that I can't quite put my finger on.
There is three wires that run behind the intake manifold to some sort of sensor but they are not in a plug just individual. One comes from inside the car as if it was custom wired from the ecu. This wire is blew. There is also a black one and a black and yellow one. As far as I can tell I do not have the correct iacv setup becase this is manual car now.
Please someone lead me in the right direction. The car is idling betweeen 1800-2000 rpms or so but at this time I know I have air in my coolant.
Old Dec 15, 2011 | 02:36 PM
sfar785's Avatar
Default Re: Please help might need guidance. Minime
You will have to run an OBD1 ECU with a jumper harness as the B7 doesnt even have a space for a knock sensor.
Old Dec 15, 2011 | 02:38 PM
Yes there is fuel and spark. The car runs but idles between 1500-2000 rpms. When I bought the car from the guy it did this same thing. It sucks because I don't have his number to call and ask what all is custom. I know there is discretions between iacv on these y8 motors.
As far as I know my car is manual using an automatic y8 ecu/head/manifold with a d15b7 block and I didn't wire in the knock sensor.
Old Dec 15, 2011 | 02:41 PM
When plugging the black and yellow wire into any of the pins on the sensor on the back of the manifold it makes the idle jump to idk alot because I always have cut the car right back off. I noticed as well with the car in acc this wire will spark if it touches metal so it is a live wire.
Old Dec 15, 2011 | 06:24 PM
HondaPartsHero's Avatar
Technical Hero
I'm assuming the car is OBD2? Not sure if you can but on B series for LSVTEC people do this
Using a 10.9 mm drill bit, opened up the hole on the bracket and the block. Then carefully tap the hole with a 12 mm x 1.25 thread pitch tap. Be sure to clean up the shavings and then screw the knock sensor. This will keep your ECU from throwing any codes.
Old Dec 18, 2011 | 08:42 PM
That does look nice and stock for the knock sensor. Wish I had done this with the motor pulled out of the car.
Old Dec 18, 2011 | 08:54 PM
ssmtyper's Avatar
just get a obd2 -obd1 jumper run a chipped p28 with knock bypassed in the tune... or else your minime is pointless as a stock vtec ecu will not crack vtec with out signal from knock/VPS/VS...
Old Dec 4, 2012 | 06:40 PM
Johnny_9's Avatar
What is the existing Existing Bolt Size / Thread Pitch that was drilled out - M10 x 1.25 ?
dmt0000
Oct 15, 2012 08:12 AM
dafuzzbudd
Jul 2, 2008 05:16 PM
toolbox21
May 28, 2008 04:02 PM
1slowcrx
Apr 2, 2008 10:32 PM
stivic
Jul 7, 2007 07:08 PM
