Does a 98 have a EGR port system like a 96..
Mad Mike, my brother just called and his 200k 98 is throwing multiple cylinder misfire codes just like my 96 did. The EGR port clean out solved my problems and was wondering if his setup is like mine. As somebody posted , if your ports are not cleaned out SOMETIME, they will be later.....
Is ia a 2.3 or a 3.0? The only way to clean out the egr system effectively on a 2.3 is to remove the upper manifold plenum. Once removed, you can access the egr ports. The F23a1 egr system also plugs up in the upper plenums port where the flow makes a 180 degree turn. You almost need a spoon to scoop out the crud that builds up in there.
Found out it is a V6 and the car is stumbling at low RPM. Planning on taking down the EGR system down to the ports and ensuring they are clean and working properly. Will let ya know what we find.
