On my way to Whitfield Racing to get tuned!
Like the title says today is my appointment (10am) for my ls-t to be tuned.
B18b1 rebuilt with arp head studs and acl bearings.
t3t4 @ 10 psi
3 inch down pipe
rc 550
crome
obd-1
thrush exhaust
Obx throttle spacer
ngk #7s
walbro 255
Im leaving now and wont be on till later on so lets see who can guess how much power i made....
t3t4 @ 10 psi
3 inch down pipe
rc 550
crome
obd-1
thrush exhaust
Obx throttle spacer
ngk #7s
walbro 255
Anyways.
Didnt make much horsepower since i have a mysterious boost leak.
Installed a 8 pound spring and was only boosting 4 and dropping to 2.2 by 5k rpm.
Car made 145.7 hp and 153 ft-lbs of torque.
Im guessing find leak,do valve adjustment then retune.
Still pulls hard. and runs smooth.
Thanks to kevin at Whitfield. Cool Guy!
http://www.srtforums.com/forums/f75/...-bucks-582089/
Get a rubber cap from your local hardware store that fits your turbo inlet.
Pressurize the system with an air compressor that is regulated. Turn the regulator down to around 20-30 psi...
With the engine off, Throttle body shut... pressurize the system. Listen for leaks.....
You don't even have to use a valve as used in the thread link I provided. Simply use a barb fitting or poke a small hole in the rubber cap and use a barbed air chuck...
DAYYYUUUMMM!!! good **** bro!!!!
hey just one question!
pressure it to 30 psi? this wont affect turbo,seals,compressor right?
The seals will be fine. You are trying to create enough pressure to where you will hear leaks.
Also, I have seen blow of valves leak during runs but not during a boost leak test.
You must not understand Blow Off Valves very well... Here, read this...
http://en.m.wikipedia.org/wiki/Blowoff_valve
If a BOV doesn't stay closed during boost what does that mean? It vents off pressure. Speaking from experience, boost leaks can be a tricky thing unless you do the afore mentioned test. So regardless, do the test and you will see if it's a boost leak from your BOV or something else. As stated before - if it tests good, then it's most likely your BOV. You can try to check it by disconnecting the vacuum line going to it.
Sprockets
May 3, 2005 09:18 AM
z6
Jan 17, 2005 05:35 PM
