Timing belt jump a tooth or too
Old Oct 7, 2002 | 08:22 PM
MisterB's Avatar
Default Timing belt jump a tooth or two
so i was driving along and blamo my 91 si aint going no more... i guess the tensioner broke or cam loose and the belt jumped a tooth or two not sure yet just towed it home and went inside...
my question is do you think i bent some valves or can i just put it back and on the correct tooth and will be good to go? thanks
[Modified by cl4show, 5:22 AM 10/8/2002]
Old Oct 7, 2002 | 08:24 PM
FUP23's Avatar
New User
Default Re: Timing belt jump a tooth or two (cl4show)
I dont thin you should worry about bent valves at all ..Just worry about getting a new belt and tensinor and best of luck
Old Oct 8, 2002 | 11:37 AM
MisterB's Avatar
Default Re: Timing belt jump a tooth or two (Devin17)
i dont know if it was the tensioner, i think frozen or broken water pump makes more sence.
i just want to register this car i have a b16 just waiting to go in i feel like im just wasting money on the stock motor
Old Oct 8, 2002 | 05:40 PM
MisterB's Avatar
ok fixed the prod it was the distributor belt did not jump thanks though
tegsr2o3
Mar 24, 2009 02:03 PM
kb7709
Apr 22, 2006 11:16 PM
Jayboy
Sep 3, 2005 03:37 PM
ReV LiMiT
Jan 25, 2005 10:11 PM
civic_hatchback
Jun 10, 2004 10:23 PM
