Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
MEGAN RACING DAMPER KIT SUSPENSION
Old Dec 15, 2011 | 12:29 AM
drew@tna_auto's Avatar
Default MEGAN RACING DAMPER KIT SUSPENSION
Our most recent addition to our expansive coil-over kit line up, the EZ STREET coil-over line up is aimed towards the more budget oriented enthusiast to offer the most basic essentials from an after-market coil-over setup, yet makes no compromises for quality and performance.
Features:
- Spring Rates: 10kg Front and 5kg Rear
- 15 Levels of Adjustable Damper Strength
- Aluminum Brackets paired with rubber inserts
- Rubber Dust Covers
- Adjustable Ride Height
- Conservative Spring Rates
- Single-Cylinder Design - monotube
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
COST 680 shipped in the US
APLICATIONS
Honda Accord 03-07 / TSX 03-07
Honda Accord 08+ / Acura TSX 09+
Honda Accord 90-97
HONDA ACCORD 98-02/ ACURA CL 98-03 / ACURA TL 98- 03
HONDA CIVIC 88-00
ACURA INTEGRA 90-01
HONDA PRELUDE 92-01
HONDA S2000 00-09
megan racing street damper kit
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
SPECIFICATIONS & FEATURES:
APPLICATION:
Honda Civic 1992-1995 EG6/1996-2000 EK9
Acura Integra 1994-2001 DC2/DC4
Honda Civic/CRX 89-91
Acura NSX 1991-1999
Acura RSX Base/Type S 2002-2006
Honda Civic 06+ (including Si models)
an more check meganracing.com
SPRING RATES:
F: 62mm ID; 180mm length; 12 kg/mm
R: 62mm ID; 180mm length; 6 kg/mm
DAMPER SPECS:
F: 95mm stroke; 190mm length; A2 valving code
R: 95mm stroke; 200mm length; A1 valving code
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Aggressive Spring Rates
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
COST 880 shipped in the US
Old Dec 15, 2011 | 12:34 AM
Default Re: MEGAN RACING DAMPER KIT SUSPENSION
bu,mp
Old Dec 15, 2011 | 07:33 PM
ttt
Old Dec 16, 2011 | 05:47 PM
bump
Old Dec 27, 2011 | 10:51 AM
ttt
Old Jan 11, 2012 | 10:51 PM
ttt
Old Jan 17, 2012 | 07:28 PM
bump
Old Jan 21, 2012 | 06:32 PM
ttt
Old Jan 21, 2012 | 06:42 PM
ttt
Old Jan 23, 2012 | 07:43 PM
bump
Old Mar 16, 2012 | 11:05 AM
ttt
Old Mar 16, 2012 | 04:49 PM
bump
Old Nov 12, 2012 | 12:10 PM
ttt
Old Nov 28, 2012 | 10:31 PM
bump
Old Nov 28, 2012 | 10:32 PM
ttt
Old Nov 29, 2012 | 07:05 PM
bump
Old Nov 29, 2012 | 07:15 PM
ttt
Old Dec 4, 2012 | 05:53 PM
bump
Old Dec 18, 2012 | 10:25 PM
ttt
Old Jan 18, 2013 | 12:21 AM
bump
Old Jan 26, 2013 | 06:53 PM
ttt
ace_drew1
195
Apr 29, 2014 02:01 PM
drew@tna_auto
52
Mar 7, 2011 07:44 PM
RedlineMotive
13
Oct 3, 2010 08:44 PM
BLK JDM
Aug 10, 2008 07:04 PM
