how to shape body filler?
Old Dec 14, 2011 | 07:08 PM
LSteggyguy's Avatar
Default how to shape body filler?
how do i shape body filler?
i have a large dent on a rear quarter panel on a 6th gen civic coupe
and it goes from the rear wheel flare to a bit above the the body line (that stretches from the trunk to the headlight)
how do i shape the bondo to the old body lines?
and is there a tip for making it smooth? i've tried it once, and it came out with a lump in the middle that showed once it was painted, but i couldn't see it at all before any paint was on it.
Old Dec 17, 2011 | 02:17 AM
eyecandynsx's Avatar
Default Re: how to shape body filler?
Use the longest sanding block you can to get it flat. Remember, your body filler shouldnt be more than the thickness of a dime. When you think youre close, use a guide coat and go back over with a sanding block. Then youll see high and low spots. But honestly from the way you described this dent and without seeing pics, it sounds like it may be too big / deep for body filler.
Old Dec 17, 2011 | 10:54 AM
joeshmo's Avatar
I concur. Pics would help but sounds like a good candidate for a stud gun and slide hammer.
amrussellusn
Paint and Body
Oct 7, 2012 03:13 PM
evilclown312
Paint and Body
Jun 27, 2012 12:06 PM
a97b18b
Paint and Body
Aug 7, 2010 04:44 AM
Pooby88
Paint and Body
11
Apr 4, 2008 02:10 PM
-[95cxhatch]-
14
Feb 14, 2006 08:31 AM
