Noise from the front right wheel/suspension area
Hi,
This has been bothering me since a while now. I had one of the local mechanics take a look. And as per his diagnosis replaced several parts already. Upper Control Arm, entire Strut assembly, Link and Bushings.
But the noise continues. I had replaced the rotors and pads too recently. I still don't understand what's causing the noise.
I hear the noise more when I go over road bumps. But also when the car stops or starts moving.
This is driving me nuts. Any suggestions please?
thanks
thanks
Jack up right side of car then spin the tire (car in neutral). If it is the bearing you will hear a spinning, gringing sound. Grab the tire at 3 and 9 oclock and see if you can alternate pushing with one hand and pulling with the other. Try at 6 and 12 oclock also. If there is movement the bearing is bad.If the bearing is good you could have a bad differential bearing or half shaft. Further investigation is needed.
OP, it may be that the sway bar endlinks are loose on that side which will make noise when you go over bumps due to the lower control arm that has to travel up and down. I've dealt with this before where some techs won't find it at all and I'd go in there with a prybar and lightly pry where I'd see bushings that I know squeaks or rattle. But, you never tell us what kind of noise your car makes? Squeaks, cluncks, rattles??????
And don't forget to check the strut rod bushings.......and I agree, bearing and UCA can cause noise,,,,,,however, never throw parts at an issue without testing/confirming
Not the literal Upper Control Arm, and I didnt say the bushings weren't the problem. Y'all need to read first, type second and proofread third.
hmm its too bad you cant replace just the bushings you have to replace the whole upper control arm..maybe you should do some research first
I have the same issue in my car. Replaced EVERYTHING in suspension and steering and still the squeaks and bumps persisted.
Problem was in fact elsewhere.
CHECK THE ENGINE'S central mount, the front one near the radiator.
If the rubbers are gone it will sound like beaten-up suspension.
bambbrose
Oct 11, 2015 08:01 AM
