How do I keep water out of my del sol
My del sol leaks around the top of the windows. It looks like the contact with the window and seal isnt good enough. Whats the best way to get that fixed? Im tired of riding around in a wet seat. Thanks.
1) Clean all your roof seals with silicone grease, preferrably shin-etsu (available from dealers, I bought a bunch of tubes a while back from one over the internet), and a clean (disposable) rag.
2) Remove all your roof plastic panels to expose the mounting bracket underneath. They're held on with snap fittings, if you pull them straight down with enough force they should come right off.
3) Loosen side bolts, install targa on car (don't flip levers), push side panels (roof seals) out, get the targa panel square on the car
4) Roll window up, then try to get an even seal against the window. You may need to get out the other door of the car and look at them through the window to get an accurate judgement of your handiwork.
5) Tighten up bolts, flip lever, tighten remaining bolt, get out, inspect your handiwork from the outside
6) Repeat previous steps for other side of car
7) Remove targa, reinstall plastic panels, enjoy
In all likelihood unless your car never got retrofitted to 95/96+ seals (there was a recall for it), this is all you'll need to do. As the car gets older the car sags and the door seals need adjustment.
Note that if you really push the side panels too hard you'll break the rear window seal so that's why you want to loosely adjust everything then snug them up.
There's a bit of artistry in getting a good seals all the way around but go slow and keep futzing with it and you should get the hang of it. Took me a couple tries before I figured it out.
Oh and when adjusting/tightening up the second bracket, be sure to leave the window rolled up and the door closed on the opposite side of the car when futzing it, otherwise you'll probably end up forming a brace that pushes the windows out, which will cause leaks at the front and rear of the side windows.
With both brackets at maximum adjustment they'll basically brace against each other and push the windows out. You just want a snug fit with cleaned seals.
Last time I bought a tube of grease it cost about $20, but you can get at least 2 years out of one assuming you do it 2-3 times a year. I usually clean mine in the spring and in the fall, basically before & after winter because it beats the hell out of the seals.
RamaCRX
16
Oct 26, 2012 07:48 PM
hermanssol
Jan 26, 2008 05:42 PM
Squallie
27
Oct 7, 2005 04:56 PM
