tial turbine housing vband clamp alternatives
Old Dec 14, 2011 | 05:49 AM
hootiehoo's Avatar
Default tial turbine housing vband clamp alternatives
do any of you know about alternatives?? ive been looking everywhere and cant find any.
i just find it hard to believe nobody offers a clamp that works.
Old Dec 14, 2011 | 09:04 AM
hootiehoo's Avatar
Default Re: tial turbine housing vband clamp alternatives
http://www.ebay.com/itm/Stainless-V-...38098354926694
i know these exist, obviously china copies, but with shipping, they are only like 10$ cheaper.
i just cant believe nobody has found an off the shelf clamp without the tial logo on it that is under 36$
Old Dec 14, 2011 | 09:08 AM
kyden's Avatar
measure the outer diameter of the flange and find a clamp that fits?
Old Dec 14, 2011 | 09:42 AM
hootiehoo's Avatar
http://www.siliconeintakes.com/produ...454d717788391a
for 9$ im gonna try it unless people already have?
Old Dec 14, 2011 | 10:27 AM
CVC9216's Avatar
^I would not use a $10 clamp to hold my turbo on. There is more to the clamp fitting than simply the outer diameter
Old Dec 14, 2011 | 02:57 PM
RickyLee53's Avatar
Yes the angle and width of the flange also play a part. However $36 from Tial is expensive.
Old Dec 14, 2011 | 04:34 PM
hootiehoo's Avatar
i saw on one of these threads a blueprint of the turbine flange. it indicated the angle was 20 deg. i bet you dollars to donuts there is a compatible flange out there...ill update when i find one....unless one of you monkeys do first!
Old Dec 15, 2011 | 05:02 AM
HellaFab's Avatar
the cheap ones in my experiance suck.
The TiAL ones are leaps and bounds better quality and will work for years not weekends.
Old Dec 15, 2011 | 09:49 AM
hootiehoo's Avatar
really? i mean its not like tial is making clamps, they just order them and have the logo engraved. that same place that makes them i gaurentee you makes them for others, and doesnt charge 36$ a clamp. just need to find one that fits.
Old Dec 15, 2011 | 11:53 AM
RickyLee53's Avatar
We have some that are better quality than the Tial, not a lot cheaper and i'm in the Uk so not much help either.
Old Dec 15, 2011 | 12:07 PM
hootiehoo's Avatar
do they fit the tial housing?
link?
Old Dec 15, 2011 | 08:45 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
What about clampco
Old Dec 16, 2011 | 05:40 AM
hootiehoo's Avatar
just put in a quote to clampco with all the dimmensions.....
i asked for a total of 10 and if they have one that is off the shelf that would work.
i know a custom clamp would probably be at least just as expensive since im sure tial buys more than 10 at a time...
Old Dec 16, 2011 | 12:37 PM
hootiehoo's Avatar
ive spent the last two days doing nothing buy clamp research. i am now an expert on vband clamps! hahah
i have found a clamp that is OE on a domestic car, and matches the dimensions of tial's turbine inlet flanges, however it is sold for about the same price. The good news is that it is still found on recent cars, and it is a very popular car, so you can score this vband at a junk yard for probably a few bucks. it is also made by a reputable company.
im going to buy one and find out how well it fits, but i spoke with the manufacturer, and the dimensions are all spot on (outer diameter of flange, innter diameter of the V part of the flange, angle of the V part, and thickness of the two flanges mated up at the OD of the flange, and ID of the V part).
Old Dec 16, 2011 | 12:45 PM
hootiehoo's Avatar
here is a picture of the clamp, i will give part number and the make/model/year it is found on once i physically verify it works.
Old Dec 19, 2011 | 08:28 AM
hootiehoo's Avatar
http://www.mcmaster.com/#quick-clamp...ttings/=ffkrj1
i think this would work as well.
the v gap loogs good, and the OD is about right.
it says 400 deg operating temp, but i bet thats according to the gasket used. with no gaket, its just a piece of 304ss
Old Dec 19, 2011 | 08:30 AM
hootiehoo's Avatar
http://www.mcmaster.com/#quick-clamp...ttings/=ffkt66
also this, just replace the **** with a lock nut.
Lewy. Dee Ayy
Aug 5, 2013 07:02 PM
b00st Junkie
Nov 25, 2005 02:59 PM
DD_JonnyLee
Jun 14, 2004 08:13 AM
GraphiteAccord
Nov 6, 2002 01:16 PM
