apexi power fc
any body running one of these power fc's if so what all do i need to run it?do i just need to buy a obdo to obd1 adapter and it will plug in.i keep looking but not finding much about them.
that is because no one uses them on hondas.. see "why piggybacks suck on hondas"
If the apexi power fc plugs into a obd1 ecu plugs then you need a jumper harness not an adapter. You'd have to convert your car to obd1 which isn't too expensive and if you do change your mind about the power fc there are way more options for tuning on obd1
