First time Tig welding (pics)
Old Dec 13, 2011 | 02:21 PM
arc_55's Avatar
Default First time Tig welding (pics)
Machine: Miller maxstar 150
Material: 304ss tubing .060 thick
Gas: 20-25 cfh
tungsten: red
filler rod: 316l i believe its 3/16ths
First time tig welding and i have years of experience with mig welding. I have found the weld seem to be very grey and turning the amperage down doesn't help or increasing the cfh. It seems like a heat issue to me, but as soon as i turn it down its just harder to start and maintain a puddle.
Any help would be appreciated! Critique it any way you like!
thanks
Old Dec 13, 2011 | 03:41 PM
Ratt731's Avatar
Default Re: First time Tig welding (pics)
Not bad for first time doing tig
Old Dec 13, 2011 | 09:09 PM
RadekSkylark's Avatar
What amperage did you use? What post-flow setting? What gas lens/cup? How fast did you move?
Also I'm not sure is there really such a size for a filler - 3/16", maybe it's 1/16"? Anyway, they both are too big, try using .035-.045", you should see some gains only from that IMO.
And yeah, the bead looks great for a first timer!
Good luck
Old Dec 14, 2011 | 11:52 AM
arc_55's Avatar
Good luck
I will get the details for you i'm not at the welder right now. Sorry i do think its 1/16ths you are right!
I am going to pick up some smaller filler rod and see what happens
Old Dec 16, 2011 | 06:31 PM
arc_55's Avatar
So i am not sure the cup size on the welder currently, but i am gonna order up a bigger one possibly #10. Also the weld craft 17 torch that came with the miller maxstar does not have a gas lens so i am upgrading to a gas lens with the new cup i will give it a try.
Old Dec 16, 2011 | 11:06 PM
Get Large Gas lens + #12 cup, most on here have found it the best midway, also I'm using it with good sucess.
Old Dec 17, 2011 | 07:21 PM
95TurboCivic's Avatar
thank you sir great advice
Old Dec 17, 2011 | 11:24 PM
Glad I could help!
Good luck!
Ash J. Williams
Welding / Fabrication
16
Nov 13, 2012 11:25 AM
i drive a honda
Jun 1, 2009 01:32 AM
Richie V6
49
Dec 8, 2008 04:13 PM
silentdaredevil2
Jul 3, 2006 07:51 AM
shortyz21
25
Jan 7, 2006 04:11 PM
