94 civic d16z6 wont start
Old Dec 13, 2011 | 10:16 AM
glockoma818's Avatar
Default 94 civic d16z6 wont start
i have a 94 civic d16z6 wont start.was running fine. ran out of gas, put more in but now doesn't want to turn on. any body know what could be a problem???
Old Dec 13, 2011 | 10:25 AM
Dc4LsTeG's Avatar
EK9
Default Re: car wont start
Is the fuel pump priming when you turn the key? Have you checked for spark?is the engine turning over at all when you try and start it? We need more info.!
Old Dec 13, 2011 | 10:36 AM
sfar785's Avatar
check your injectors and see if they're clogged, you may have sucked some stuff up from the bottom of your tank when you ran out of gas
Old Dec 13, 2011 | 10:39 AM
changed the plugs, rotor, and ignition module. and checked to make sure fuel is going up to the injectors.
Old Dec 13, 2011 | 10:40 AM
does turn over.
Old Dec 13, 2011 | 10:42 AM
Dc4LsTeG's Avatar
EK9
Fuel pump priming?
Old Dec 13, 2011 | 10:43 AM
if the injectors are clogged how can i clean them?
Old Dec 13, 2011 | 10:44 AM
yes it is priming.
Old Dec 13, 2011 | 12:24 PM
EGLivin's Avatar
Check to see if your actually getting spark. Then check to make sure that your actually getting fuel. Also I know it sounds stupid but did you put more gas into it. My brothers car wouldnt start and turns out he had no gas in the tank. Try and give it a little gas while your turning it over.
Old Dec 13, 2011 | 12:27 PM
hahah yeah it has a lil over 1/4 tank of gas.could it possibly be my main relay?
Old Dec 13, 2011 | 12:28 PM
Dc4LsTeG's Avatar
EK9
Yes check to see if injectors are clogged and make sure your getting spark
Old Dec 13, 2011 | 01:37 PM
I just took the injectors off and I'm soakin them in injector cleaner.
Old Dec 13, 2011 | 01:40 PM
Dc4LsTeG's Avatar
EK9
Did you check for spark yet
Old Dec 13, 2011 | 03:23 PM
Cjlarson14's Avatar
INJECTORS ARE GOING TO HAVE NOTHING TO DO WITH THE ENGINE NOT TURNING OVER! Check your battery and your distributor. Neither of those. Check spark plugs and wires. If you don't know how to do either of the four, read the manual.
Last edited by Former User; Dec 15, 2011 at 09:49 AM. Reason: Thread clean up. Keep the tech discussions civil.
Old Dec 13, 2011 | 03:25 PM
Dc4LsTeG's Avatar
EK9
if you could read properly it says the car turns over
Old Dec 13, 2011 | 03:27 PM
Wrona's Avatar
if you would read you would notice that the car is turning over its not starting if the injectors are clogged there is not enough A/F ratio in the cylinders to start the car
Check for spark
Last edited by Former User; Dec 15, 2011 at 09:51 AM. Reason: insulting comment deleted. Enough is enough.
Old Dec 13, 2011 | 03:31 PM
Cjlarson14's Avatar
Originally Posted by Wrona
if you would of read you would notice that the car is turning over its not starting if the injectors are clogged there is not enough A/F ratio in the cylinders to start the car
Check for spark
Injectors are gunna be one of the last few things of why the engine won't start. Basics 101. Thus spark is what I said next. Well wires and plugs.
Old Dec 13, 2011 | 03:33 PM
Wrona's Avatar
The op has said nothign about spark yet and it has been mentioned liek 3times but seems like he hasnt gotten around to it
Old Dec 13, 2011 | 04:05 PM
there is spark. new wires,plugs,rotor,ignition module. cleaned injectors tested on car to make sure they are spraying properly. checked all fuses.
Old Dec 13, 2011 | 04:06 PM
Dc4LsTeG's Avatar
EK9
Did you check all your grounds?
i try turning the car on and here a clicking sound in the fuse box inside the car,from a relay.
Old Dec 13, 2011 | 04:08 PM
checked the ground on the battery, and starter
Old Dec 13, 2011 | 04:12 PM
Dc4LsTeG's Avatar
EK9
Main relay fuel pump relay?did you check the thermostat and vc ground?
Old Dec 13, 2011 | 04:50 PM
thermostat is a couple of months old. main relay. ill have to go back and check the ground on the thermostat.
Old Dec 13, 2011 | 06:25 PM
Dc4LsTeG's Avatar
EK9
Yea I was talking about the ground on the thermostat not the thermostat itself
