b18c will not rev past 6500 rpm
Old Dec 13, 2011 | 03:59 AM
KiLLa CaM 06's Avatar
Default b18c will not rev past 6500 rpm
motor runs fine, vtec kicks in and there is no CEL but it will not rev past 6500 rpm. I had checked the timing, changed out the rotor button and cap, new wires, plugs, fuel filter, and a fuel pump.current engine mod is skunk 2 intake manifold, aem cold air, tri y header and exhaust, chipped ecu.
Old Dec 13, 2011 | 07:37 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: b18c will not rev past 6500 rpm
Any chance the tach reads incorrectly? Very common issue.
Old Dec 13, 2011 | 07:39 AM
sfar785's Avatar
take your ECU out and look to make sure there isn't any scorch marks....and look at your chip, also try a friends ECU if you can to cancel that out.
Old Dec 13, 2011 | 09:53 AM
tried my cousins ecu and its doing the same thing. Will try the dizzy next.
Old Dec 13, 2011 | 03:03 PM
jdmadam's Avatar
does vtec engage?
Old Dec 13, 2011 | 03:12 PM
Yes,vtec does engage
Old Dec 13, 2011 | 03:17 PM
Cjlarson14's Avatar
Had this happen recently to my d16 and couldn't find the dam issue. Check your fast idle valve. Was my issue. Not even Honda themselves could figure it out. Wouldn't rev past 5800 though for me.
boost and bass
Mar 31, 2009 06:06 PM
ChinitodeNJ
Oct 6, 2006 06:31 AM
MattGP523
Oct 23, 2003 01:50 PM
Hondasaurs
Nov 18, 2002 04:32 AM
SohcVtecCrix
Sep 14, 2002 07:23 AM
