OR 93' Delsol[Built&boosted] Northwest! 7k
6k
clean title in hand(real SI) Read post!
ls-vtec
8-10k miles on the build
81mm ls sleeves
nippon performance pistons/rings/pins
balenced ls rods with arp studs/bolts
cometic bottom end gasket kit
apocalypse racing oil pump
acl race rod bearings
acl race main bearings
micro-polished crank
itr crank pulley
Gates racing timing belt
ARP Headstuds
Cometic 81mm/.36 thickness headgasket
hondata intake manifold gasket
B16 head with type r valve cover
custom catch can setup
mild Port N polish
3 angle valve job
STR cam gears (tuned by english)
GSR cams
GSR valves
GSR Valve springs dual intake side
Garage 808 built B16 Tranny with ls 5th gear
ACT 4 puck unsprung clutch with ACT extreme pressure plate
itr flywheel 14lb's
P28 ecu chipped on chrome pro
omni 3-bar map
Garrett 57trim 60a/r with stage 3 turbine
turbonetics bell inlet
Ramhorn manifold made by Fam at Forged performance
ETS intercooler
38mm Tial wastegate
blitz bov
660cc injectors
walbro 255 pump
3" downpipe/exhuast made by English Racing
vibrant 3" muffler
dump tube made by English racing
innovative 60a polished motor mounts
full k-sport coilovers
4x114 hub/brake/wheel coversion (96 type r integra)
205 proxi 4's in front
195 falken's on back
skunk 2 lca's
DNA lower strut bars
mugan upper front and trunk bars
full aem wideband air/fuel and tru-boost gauges
apexi turbo timer
skunk 2 short shifter
skunk 2 shift ****
boss hub
nardi steering wheel
AND MORE
only downside is the paint is faded but with just a quick paintjob you can easily throw it in shows or have one of the cleanist and quickest delsol's around the northwest! i won third place import at albany's (daretoocruise) event even with the faded paint!
tuned by TJ at english
8200 rev limit
5200 2step(launch control)
353whp (highboost)
325whp (midboost)
300whp (wastegate)
HAVE the dyno sheet!
13.06 at 114mph on 10psi (break in tune around 250-280whp) running proxi 205's v
With the right wheel set-up this is a 11sec car
((((((((((((((((541-401-7376))))))))))))))))
ls-vtec
81mm ls sleeves
itr crank pulley
ARP Headstuds
mild Port N polish
3 angle valve job
GSR cams
GSR valves
itr flywheel 14lb's
omni 3-bar map
ETS intercooler
38mm Tial wastegate
blitz bov
660cc injectors
walbro 255 pump
vibrant 3" muffler
skunk 2 lca's
apexi turbo timer
skunk 2 shift ****
boss hub
AND MORE
8200 rev limit
353whp (highboost)
325whp (midboost)
300whp (wastegate)
