Spoon sports Cailpers On a EG9?
No Sales Forums
whats up Honda-tech I was wonder if its possible and safe to run Spoon Sports cailpers(DC2 5 LUG) on a EG9 Hub using a Power slot slotted rotors and hawk hps pads and The Spoon Sports 3mm Spacer that goes in between the rotor and spindle? And if not what tweaks must be done to work? Thanks
You may need extended studs but it's up to you if you feel you get enough turns when you tighten the lug nut down.
Also, make sure you get the correct size rotor as you will need a 11" rotor for this. You may need a spacer to clear your wheels after as well.
The only thing you might want to make sure about, is the thickness of the rotor and if it will center within he caliper.
is there any other upgrades needed (for a B-series EG Hatch) to use these 4pot?? like the servo or something?
ive also thought about using Nissan 4pot calipers on my ride...
i already have the BB1 rotor+caliper setup on my ride
