1997 Honda Civic Ex NOT STARTING
Old Dec 12, 2011 | 06:18 AM
USDM DUH's Avatar
Default 1997 Honda Civic Ex NOT STARTING
I have a 1997 Honda civic Ex with a bone stock D16y8. The car is getting gas, and spark. All the plugs have checked out, distributor, fuel pump, injectors, etc etc.. I have ruled out most any mechanical problems and now I am wondering if it could be a sensor?? I honestly believe it is the crank position sensor but I am not 100% and would greatly appreciate help or advice
Old Dec 12, 2011 | 06:19 AM
USDM DUH's Avatar
Default Re: 1997 Honda Civic Ex NOT STARTING
ALSO the car was running fine right before it cut off.. It would not start back up, however it will turnover and act like it wants to start it just won't crank
Old Dec 12, 2011 | 06:39 AM
grumblemarc's Avatar
The Grumpiest
Exactly what do you mean by "checked out"? What did you do exactly to "rule out" other issues? What color is the spark? Are you throwing any CELs?
Old Dec 12, 2011 | 07:36 AM
sde780's Avatar
It was running fine, then shut off and wouldn't start? Check the timing belt before you bend some valves
People have said the rotor screw in the distributor comes loose and their car stops running, have you checked that?
Old Dec 12, 2011 | 04:17 PM
motegicivic's Avatar
Check your battery's voltage, 12 volts with key on at least.
Check the coil.
I think a crank sensor would set off a code.
Old Dec 12, 2011 | 07:59 PM
phat00civic's Avatar
Is there a kill switch in the car or an alarm? This will make it feel like it will start but will not. I would double check voltage (14v) and that its not the starter for sure.
Old Dec 12, 2011 | 08:06 PM
DCSportEJ1Civic's Avatar
most any sensor that would cause the engine to not run would either control fuel or spark in some way. youve either missed something or tested something incorrectly(not being a smart ***).
The engine cranks over when you hit the key, but wont fire. you either dont have spark, fuel, compression, or timing. i assume you can check spark so I would do a compression test next to rule out mechanical issue again. if timing is off far enough to cause a no start you would probably have bent valve ie, no compression. make sure you have fuel pressure, and make sure your injectors have power at all times with the key on, and a ground pulse signal when the engine is cranking over.
Old Dec 14, 2011 | 04:20 AM
USDM DUH's Avatar
It is getting gas, spark plugs are new and the spark wires to BUT they have been taken out and checked twice. The spark was just a normal color spark I would guess, it was white and all 4 had spark. I have taken the VC off and timing belt and timing are still OK I hooked up the scanner yesterday and it gave me 6 codes.. p0301-p0304 which are all cylinder misfire codes and I got a p1300 which didn't have a DTC in the scanner and the last code I honestly forgot but it said Misfire on any cylinder
Dizzy check out, and was replaced just incase anything happens down the road
Check the coil.
It did throw a code but nothing about a crank sensor.. I'm not sure what it could be
The only thing that has went uncheck would be the compression. I will go check that after I reply to these messages. Like I said up top the timing belt and timing are timing gear are still in timing when set to TDC. Haven't check the injectors either but this is my buddies car and I am trying to help him out and I am at a loss right now. I will update this when I get the compression checked out
Old Dec 14, 2011 | 06:15 AM
sfar785's Avatar
replace dizzy, then check your timing
skizman
Aug 21, 2016 07:45 AM
Justin1168
Oct 1, 2014 08:20 AM
kotehzz
May 6, 2011 06:27 PM
pinoyboy204
19
Mar 9, 2010 09:47 AM
1nv4d3r
Aug 30, 2009 06:46 PM
