CEL 15
Old Dec 11, 2011 | 12:56 PM
springs's Avatar
Default CEL 15
i just swapped in my B20b into my crx si. everything was fine when i had it in my hf. now i have cel 15 and it wont start. ive checked all grounds. ive rebuilt my dizzy and even bought a new one. any advice would be great.
Old Dec 11, 2011 | 01:56 PM
claymonthug's Avatar
Default Re: CEL 15
check your wires? thats a wired code to get on a swap. id think your distributor was bad but you say its all good. whats your wiring like? is the engine harness the si harness? or some other modded harness?
Old Dec 11, 2011 | 02:44 PM
springs's Avatar
Default Re: CEL 15
its the si harness but i got it from rywire.
Old Dec 11, 2011 | 02:58 PM
Default Re: CEL 15
well you say you rebuilt the distributor? did they have two options for a coil based on who made the dizzy? id try swapping over to a known working distributor just to get that out of the way
Old Dec 12, 2011 | 06:26 AM
jlicrx's Avatar
Default Re: CEL 15
sounds to me like you are trying to use a HF engine harness with the Si chassis harness, which won't work - what are the wire colors in the round 8-pin connector at the driver's side firewall connection?
Old Dec 12, 2011 | 07:14 AM
4drEF's Avatar
Keyboard Humorist
Default Re: CEL 15
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/htf-do-you-fix-code-15-a-1656532/
It's amazing what search can find.
Link has pages from the repair manual so you can do a proper trouble shoot.
Old Dec 12, 2011 | 04:06 PM
springs's Avatar
Default Re: CEL 15
i just check the 8 pin round plug and the colors of the wires are different, so ill go swap over the harness and let you know. thanks for the help on that one i never know that crap. learn something new everyday. thanks.
Old Dec 12, 2011 | 07:34 PM
springs's Avatar
Default Re: CEL 15
BINGO that was it. thanks jlicrx
{EF9} GrEaZe m0nKeY
Oct 10, 2009 08:51 PM
Hatch-E
Oct 27, 2007 07:17 PM
4cefedcrx
Mar 29, 2006 04:53 PM
pyro_freak8
12
Mar 24, 2004 12:24 PM
