Fuel injector issue
Old Dec 11, 2011 | 12:01 PM
civic89si666's Avatar
Default Fuel injector issue
I have a 95 Cx with a b18. I took the motor out to repair some issues and have recently put it back in. When i tried to start it it wouldnt start. Sprayed some starting fluid in it and it started fine but cut out. Long story short, no fuel. I noticed my #1 injector plug is kinda messed up, would that cause them all to not work? Or is it something in the harness? Fuel filter and pump work fine. Any ideas?
Old Dec 11, 2011 | 12:10 PM
Former User's Avatar
Default Re: Fuel injector issue
Does the pump prime?
Old Dec 11, 2011 | 12:46 PM
Wrona's Avatar
does the main relay click?
Old Dec 11, 2011 | 12:48 PM
grumblemarc's Avatar
The Grumpiest
Define "kinda messed up".
Old Dec 11, 2011 | 03:36 PM
The female part inside of the plug, the metal piece is bent a little bit. And main relay clicks and pump primes.
Old Dec 11, 2011 | 04:37 PM
Is there bright white spark at all four plugs?
Old Dec 11, 2011 | 05:02 PM
yup, spark is good. i switched to another ecu and the car still wont start.
Old Dec 11, 2011 | 05:17 PM
NotAJDMFanBoy's Avatar
You could try loosening the fuel hose to see if you are getting fuel pressure. You could have a clogged fuel filter. Make sure the 4 wire plug for the injectors is plugged in and put a screwdriver on an injector and hold it to your ear while someone cranks the motor to listen for clicking of the injector opening and closing. The main relay is actually 2 relays, so just because you hear clicking doesn't mean it's working right, just that at least one side is clicking. One side turns the power on to the ECU and other stuff, and other to the fuel pump. If you hear the pump prime, do you see the CEL light turn on and then off after 2 seconds?
Your timing could be off where maybe the starting fluid will make it run, but it won't run right on gas. TPS and MAP sensor wires can be plugged in wrong and make it run bad and maybe starting fluid was enough to make it sputter at least.
Old Dec 11, 2011 | 05:19 PM
Ok, Ill check the fuel filter again but I just put a new one on it. The CEL turns on then off after the pump primes. when the pump primes i can touch injector #2 and feel the noise as the pump primes. but thats it. Ill check the tps and map sensor wiring as well.
Old Dec 11, 2011 | 05:23 PM
TPS and map sensor is good. Timing is mechanically right. TDC was set when i put the motor back together.
Old Dec 11, 2011 | 05:25 PM
And what four wire plug are you referring to for the injectors?
Old Dec 12, 2011 | 06:34 PM
Any ideas guys? I just want to drive my damn civic.
Old Dec 15, 2011 | 04:49 AM
Any ideas guys?
Old Dec 20, 2011 | 05:49 PM
Ok, so I checked the injectors. They have power to all of them. Still no fuel into the cylinders. Any idea?
01integra_gsr
Dec 10, 2011 11:08 AM
weaponsgrade
Jan 8, 2010 09:55 AM
axionm1k
Jun 4, 2008 09:09 AM
allmotor2.1
Nov 24, 2007 04:52 AM
diewX3
Jan 11, 2005 11:50 AM
