Rack & pinion on gsr
Old Dec 11, 2011 | 10:54 AM
RookieCivic's Avatar
Default Rack & pinion on gsr
I will be taking off the power steering off of my 98 integra gsr.
I was wonder since alot of the suspension is the same from civic to teg could i put the 92-95 civic rack & pinion in my integra? if so with what modification? if any?
Old Dec 11, 2011 | 11:03 AM
sebTeggy's Avatar
Default Re: Rack & pinion on gsr
Yep it will fit. I think you need different end link bushings.
But if you got your manual rack and ps rack infront of you, you can take what you need.
Also, unless you are getting your manual rack for free, just loop your ps rack? Or if you like the turn ratio on the manual rack Ill stop bothering you
Old Dec 11, 2011 | 11:44 AM
Nah i havent bought it yet.
how would i loop the power steering around? never heard of that
I might just do that its one less thing i have to deal with.
Old Dec 11, 2011 | 12:05 PM
DPancoast's Avatar
Empty the rack by turing it lock to lock maybe 6-10 times, and then loop the 2 lines into a t and install a clutch master reservoir as a breather. Or you can just leave them looped and be done I guess.
Biggest thing is getting as much excess fluid out of the rack as possible. Don't want it BONE dry since it will need lubrication to work though.
Easier and cheaper than swapping racks. Unless of course you like the manual ratio like said above. I'm spoiled and bought my teg with a quick ratio pinion and looped rack already done.
Old Dec 11, 2011 | 12:21 PM
ya i will attempted looping the lines if I dont like it i will get the rack, i mean the rack isnt expensive so im not that worried, it would be nice to turn with the rack though.
which lines have to be put in the t? the ones that come off the pump?
Old Dec 11, 2011 | 01:04 PM
DPancoast's Avatar
Nah, if you're removing p/s, you'll want to loop the lines on the rack itself. Will only be 2 of them.
Old Dec 11, 2011 | 07:22 PM
ok ill look at it some time this week if i need help ill get at ya
Old Dec 12, 2011 | 10:18 AM
Turbo-LS's Avatar
a Power rack with the pump off the car is difficult to turn. there is a reason why the manual and power rack have different ratios. the manual rack is designed to steer easier while not moving and IMO gives the driver a better feel of the car and how it reacts than a looped power rack
gotenz90640
Mar 19, 2016 03:57 PM
DohcVtec77
Mar 19, 2016 03:34 PM
kayONE
Mar 13, 2013 11:42 AM
Deej23
Mar 17, 2012 05:37 PM
Thagreybomber
Jun 17, 2002 08:27 PM
