94 integra with b16a which axle for passenger side
im new to the whole swap thing and i know the integra dosent come with a b16a stock.... i need a passenger side axle the boot is shot and its making noise i dont know if the original b18 axle is the same so i dont wanna go buy it and not fit... can anyone tell me which axle i need and the car has abs thnx....
1999-2000 Honda Civic Si Axles is the same axle as any 94-01 Integra axles. Only difference being you wouldn't need the ABS ring for an RS model.
Yeah get either 94-01 integra or 99-00 civic si.....most of the b-series motors are about the same size and that holds true with the tranny too and just cause the boot is ripped doesn't mean it needs replaced look up replacement boots....but if it's clicking/clunking when turning it deffinately needs replaced....good luck hope it helps some
i also have a 94 integra rs with a b16a2 swap but the driver side makes the clicking but only when i take off fast or turn corners what on to i use for that side????
stevenstixx
May 13, 2014 09:48 AM
civicguy395
Dec 13, 2012 03:18 AM
vdubsduncutit
13
Jun 2, 2010 05:00 PM
