BC Garage 1990 Si Build
I got this 1990 Civic SI back in late July 2011. The guy I bought the car from supposingly "worked on cars", but I got the car and it was leaking oil due to the stripped drain plug on the oil pan. It's main relay was also bad, which I changed and it is now in good working order.
Here's what the car looked like when I brought it home the first day and what it looked like after I cleaned it up a bit.
My rotors and pads were extremely bad, so I picked up a quick replacement. Stoptech Blank rotors and Stoptech Street Performance Brake pads.
I don't know if you know or not but if you dont, you can put a zip tie around the shifter just under the ring of the shift boot at the top to hold the shift boot up to the **** so you can't see the shifter. Just an idea, looks clean, like seeing all these older hondas being saved from being junk.
I purchased some Nitto Neo Gen tires as well as an EM Racing C-Pillar Bar, EM Racing Rear Strut Brace, and an EM Racing Triangulated C-Pillar Bar.
keep her clean !
