Torque Dampner Adjustment
Old Dec 9, 2011 | 03:53 PM
Velocity1's Avatar
Default Torque Dampner Adjustment
I've attached a photo of the style of dampner I have on my Lude. I'm hoping someone here can tell me the correct way to adjust it. I had to remake the brackets to properly fit my car, (re-tig welded the joints and gussetted them for strength), however none of these things are sold with install diections. It's up to the user to figure it out. Simple yes, correct not always.
I'd appreciate feedback from someone who has used one of these. I think I know I don't have the preload set right on mine so I'm looking for adjustment advice.
Thanks in advance,
V1
Old Dec 10, 2011 | 05:04 AM
Hawkze_2.3's Avatar
Default Re: Torque Dampner Adjustment
What is inside this particular damper?
I would just set it to zero pre-load and be done...
Old Dec 10, 2011 | 06:14 AM
Velocity1's Avatar
It has 2 rubber bushings and a delrin or nylon spacer that gets compressed when the motor moves. There is no zero as you say unless "zero" is where I had to adjust it to to get it between the two mount points. That's why I'm asking whether there's an adjusting procedure. Seems like you'd want to take up some of the "slack" on the internal components to minimize compression and engine movement.
Old Dec 10, 2011 | 09:01 AM
snobordboy's Avatar
Moderator
Looks like a chinese copy of the Ingalls dampner, so there probably isn't any set procedure, just do what you feel like, and hope that it looks pretty.
Old Dec 10, 2011 | 02:18 PM
Wing8806's Avatar
If this is for the front - you should have just gotten an ESP traction bar and mount.
Otherwise- i agree with hawkze, just get rid of preload and install.
royalrebel
Suspension & Brakes
10
Sep 22, 2008 04:26 PM
VBPType-S
52
Feb 27, 2008 07:44 AM
Dwight Schrute
Aug 5, 2006 04:15 PM
.water
Jul 16, 2004 06:42 AM
HX_Guy
Jan 12, 2002 10:58 AM
