Car won't start
Old Dec 9, 2011 | 03:30 PM
s13hero's Avatar
Default Car won't start
I ran out to starbucks, and I was there for a few hours, then when I came out my civic wouldn't start. I had it towed back to my place. The CEL comes on and turns off after 2 seconds, the fuel pump primes. I'm not getting any spark though. There is no voltage between WHT/BLU on the ignitor and body ground, but it passed the coil test. Any one have any ideas? BTW its a 1995 Civic DX hatch
Old Dec 9, 2011 | 05:12 PM
GoyaBuilt718's Avatar
Default Re: Car won't start
my buddy owns a d16z6 95 four door. was having the same problem. . he had to turn the key about 9 times over a course of 3 minutes to start the car. . the problem was his fuel pump relay . . even if your fuel pump is priming, its cutting some of the voltage out of the system for starting the engine. . faulty relay equals no start. . try a new one hope this helps
Old Dec 9, 2011 | 06:23 PM
s13hero's Avatar
Even if I'm getting fuel up to the filter? I forgot to put that in my OP
Old Dec 10, 2011 | 11:56 AM
s13hero's Avatar
Anyone?
Old Dec 10, 2011 | 12:02 PM
igotthaspirit's Avatar
Its normal for the CEL to come on for a couple seconds and turn back off when you turn the key on. The main relay could cause this. Try removing it and re soldering the circuit board (there is a DIY somewhere on this). Or try swapping in a known good one.
Old Dec 10, 2011 | 12:24 PM
s13hero's Avatar
Yeah I know its normal for the cel to turn on then turn off, and then it clicks, I was mentioning that as that is an indicator that the main relay functioning is it not? Also would the main relay cause no spark?
Former User's Avatar
Check whether the timing belt snapped. If it's fine, have the igniter unit inside the distributor tested.
Old Dec 10, 2011 | 12:25 PM
s13hero's Avatar
Ok thanks, how is the igniter removed? is it just the two screws on it? I was looking at it last night and it was getting dark. Also, if the igniter is bad, do you know where I could obtain another besides junkyard/dealership? O'riley doesn't list the part at all for a 95, only for for 96-00
Old Dec 10, 2011 | 12:27 PM
Did you check the timing belt?
Old Dec 10, 2011 | 12:47 PM
s13hero's Avatar
No not yet, I will but incase its fine I wanted to know how to remove the igniter.
Old Dec 10, 2011 | 03:17 PM
s13hero's Avatar
Checked timing belt its fine, I saw the cam turn, so I pulled the iginitor, going to see if autozone will test it.
Old Dec 10, 2011 | 04:10 PM
s13hero's Avatar
The igniter was bad according to autozone's test so going to pick up a new one and see. For future reference to anyone reading this, if autozone looks in their book and says they can't test the ICM (Ignition control module) tell them the test sheet is not in the book, they have to download it from the computer, by looking up your ICM.
Old Dec 10, 2011 | 10:17 PM
jdmdomo's Avatar
CHECK YOUR UNDERDASH FUSES .. ALSO ..
GL ..
Christopher Mai
18
Nov 16, 2016 03:11 PM
courtham916
Apr 11, 2014 06:57 PM
mibayaua
Oct 28, 2012 11:40 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
hookedonvtec
May 27, 2004 08:17 PM
