FS: Boost Goodies, I will keep adding parts so keep checking!
Contact: PM
Shipping: Included with prices but add 3% Paypal
Located: Orlando, FL
Garrett .60 turbo .48a/r Stage 3 wheel, 4 bolt, 1000 miles no leaks smoke or shaft play. Great spool made 341whp 243lb/tq on 10psi but found a great deal on a bigger turbo- $450
BNIB Greddy Catch can - $100
B16 Greddy Timing belt BNIB- $90
Stock bore and compression B16 pistons pins wrapped up in the box - $130
4G63 OBX turbo manifold- $350
Greddy Profec Spec B Boost controller w/manual, warranty, hardware. I wired up to my hatch but found hondata w/bbg for cheap. Never even turned on- $old
COMPLETE B18C1 Block, stock bore, balanced and micro polished crank, 9:1 Wiseco pistons, Eagle Rods with ARP rod bolts (Pistons and Rods are out of motor since bought seperately) Everything is in great condition, no defects at all - $old
60mm+ I think, some told me 60 and some told me 75 HOLLEY THROTTLE BODY **Missing spring/ throttle bracket- $old
Brand new OMNIPOWER 4 bar map sensor with o ring in plastic - $old
Dark gray Mugen Valve cover- $90 > $old
Supertech Valvetrain (Valves, Dual springs, retainers, valve seals)- $old!!!
13" Lenso's wrapped with M&H slicks Bought it on honda-tech a few weeks ago but need to sell so i can get money for tuning with John Vega. Has lots of life, the left side slick looks a little banged up from previous owners fender- $old to boost_crazy
B16 Block Decked and Honed crank is Micropolished 0 miles complete internals already assembled (NOT SHIPPING-$old
Neptune RTP DEMON installed in P28. I have license and serial number- [COLOR="Red"]$old/COLOR]
Black Valve cover Vented with bungs and AEROQUIP lines and fittings- $old to geezer_187
Ported and Polished, Hot tanked, Built with Blox valvetrain, LEGIT ITR CAMS, 0 miles comes with wrinkle red valve cover and VTEC Solenoid- $old to yewdontknowme
B16 ARP head studs, washers, nuts, engine oil BNIB- $old locally
IF IT'S STILL ON THE POST, IT IS STILL AVAILABLE
