Can the ATTS cause a wobble
My car shakes on accel.
I went under the car and when I move the left shaft up and down, it wiggle at the input of the ATTS. Are the bearings in the ATTS bad?
I'd likely say that the shaft itself is broken. Are you physically seeing the piece around the shaft splines moving? It sucks but you're probably going to have to drain it and give the shaft and ATTS unit a good inspection.
wasanissanFL
Transmission & Drivetrain
Feb 4, 2016 01:37 PM
DC 2
May 2, 2004 07:45 PM
biassj
May 16, 2003 03:57 AM
