Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
New head gasket
Old Dec 8, 2011 | 06:10 PM
Schultzie's Avatar
Default New head gasket
Just replaced head gasket on 05 civic. When trying to bleed cooling system after car reaches normal operating temp I get splashing coolant and then steam from rad. Never had this happen before. after this I let the civic cool down and then added more coolant and ran civic while pumping lower hose to try to push out all air. This seemed to do okay. Seemed like cooling system bleed just fine. I placed rad cap on after bleeding the system and then took it for a drive. About five miles down the car started to over hear and I could hear coolant boiling in overflow container. Both fans are working fine.
Anyone have ideas what could be going on?
Old Dec 8, 2011 | 07:05 PM
toyomatt84's Avatar
Sanji
Default Re: New head gasket
It can take quite a while to burp the system properly. It does go a lot smoother if you elevate the front of the car (and its even easier with a coolant funnel).
Old Dec 8, 2011 | 07:08 PM
10psiLsEf2's Avatar
park car on slant
let it get to operating temp
Bleed system
Rev to 1500 rpm for 2 minutes
Bleed again and again
DO NOT PUMP ON HOSES
Little do you know your actually not helping her!
Old Dec 10, 2011 | 05:40 PM
exb18c1's Avatar
^and don't forget to put the hot/cold selector **** to full hot.Also,do you have a proper heat inside the car when the fans kick in?If yes there is no air in the system and something is amiss.Hope for you that it isn't the case.
DEPintheCurve
15
Sep 9, 2013 01:57 PM
Aaron Cayabyab
41
Jul 15, 2012 08:47 AM
DK-EK9
Feb 14, 2012 09:20 PM
blacktibby07
Jan 24, 2011 01:35 PM
runwitme
14
May 17, 2009 04:16 PM
