Lots of parts+tuning, still feels weird
Here's my setup (98 Integra LS):
(edited because I live in a thief-happy neighborhood)
It feels really weird. Mushy and sloppy at low speeds, super-sensitive at high speeds. On the highway I have to hold the wheel almost perfectly straight or it feels like I'm going to lose control.
3 things come to mind:
- Caster angle - too high? Am I getting too much bump steer?
- Camber angles - too negative? Can that make it feel sloppy at low speeds?
- Spring rates - too low?
Can any gurus out there point me in the right direction?
I'd start by fixing whatever caused the caster issue first. Caster certainly plays a role in how the car feels.
Worn bushings, a shifted subframe, or bent control arms can all cause caster changes. I would seriously try and find the cause and correct that.
Control arms are easy enough to change, though any real issues should be visible.
The subframe should only shift in a rather serious accident, and should (guess on my part) leave visible evidence of such.
The first thing to do is clean the suspension area well and get in there and inspect.
I have the Whiteline caster kit. I would never install it, due to how poorly thought out it is. Shims placed there need to be tapered, not flat, due to the angle change between the LCA halves. They also included thinner bolts to replace the factory ones, which is also a terrible idea. All of that is IMO.
Having played with various caster settings on my Integra (SPC UCAs with adjustable camber and caster), anything other than the factory setting was just terrible. It tramlined significantly less, but produced significant amounts of bumpsteer and was slower on track.
Yeah, that caster kit is really sketchy.
This car is super clean, no evidence of anything major on the LCAs or subframe that I have noticed so far.
I wonder if the caster angle is just too high? 1.6 and 1.4 where 2.2 is the spec max. https://i.imgur.com/MA6ws.jpg
The thing that seems strange to me are your SAI and Included Angle measurements. These aren't directly adjustable, but are affected by making other adjustments. The important thing about SAI and IA is they should be pretty much the same from side to side, and if they're not, you can use them to diagnose bent parts.
SAI being off on 1 side usually indicates a problem with the cradle, lower control arm, or the upper strut mount.
Included Angle being off usually indicates a problem with the knuckle or strut.
You don't even need a spec listed, you just look at the differences. Example...
RF camber/caster/toe is fine, but LF camber is 1 degree positive. The IA for both sides is pretty much the same, but SAI is noticeably different. Since the strut tower being bent in would make camber negative, you know it's probably a bent lower control arm.
It just seems really weird to me that those numbers are so different from side to side, yet cross camber and cross caster are good. If it was my car, I'd put the stock upper control arms back on and get rid of the caster shims just to see what the camber/caster look like with stock parts.
Swapping LCAs shouldn't be too expensive. Maybe that's the next step.
Here it is before I messed with anything - https://i.imgur.com/Ez9sN.png
Type_RS_59
17
May 15, 2005 07:44 PM
