B16a Bad distributor??
Old Dec 8, 2011 | 09:49 AM
helpmyhonda94's Avatar
Icon2 B16a Bad distributor??
Ok so i have a jdm b16a in my da. When it is cold (like in the morning) it bogs like CRAZY. Once its warmed up its fine. When im driving if i give it a bit of gas it will kick a little. Also, i am throwing code 9.
What do you think? Any help is appreciated. Thanks!
Old Dec 8, 2011 | 10:19 AM
Default Re: B16a Bad distributor??
Bump
Old Dec 8, 2011 | 12:31 PM
Please!! Anyone?
Old Dec 8, 2011 | 12:43 PM
bnetkillzone's Avatar
Code 9 is cylinder position sensor according to the code list here: https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Search cylinder sensor: https://honda-tech.com/search.php?searchid=4746177
Search "Code 9": https://honda-tech.com/search.php?searchid=4746312
Old Dec 9, 2011 | 12:07 AM
mouab18c1's Avatar
ding ding ding CEL code 9. Fix that and see if it still occurs.
Old Dec 9, 2011 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
Its either a bad distributor or the wiring going into is bad.
Old Dec 9, 2011 | 11:42 AM
Im going to take it off this afternoon and see if the wiring/sensors are fried. I think the rotor is bad too. Makes a nasty noise when i start it cold. When its warm its nice to drive
Old Dec 9, 2011 | 11:43 AM
I may end up forking out the cash and picking up a used oem one off of craigs.
Old Dec 9, 2011 | 12:25 PM
DirtyDA9's Avatar
Don't just throw money at it hoping that it will fix it. Try to actually diagnose the problem. Try replacing the part that's actually throwing the code.
Old Dec 14, 2011 | 09:28 PM
Yeah, i would but i have read on other forums that replacing the cyp sensor is a bitch to replace and that you are better off replacing the dizzy
Old Dec 14, 2011 | 10:20 PM
Integra4lyfe069's Avatar
grab one at a jdm shop 60 bucks throw it in set timing n be done ! then u have a spare for parts
ADAMnQuickRDX
May 7, 2009 11:30 AM
IHEARTMYHONDA91
19
Mar 8, 2008 12:58 PM
G0crxG0
Dec 3, 2006 02:38 PM
Bobby808
Apr 7, 2005 01:28 PM
mugenbattle
Dec 13, 2003 06:12 PM
