DA is acting up (electrical issue).
I just replaced my ICU (Integrated Control Unit), and it didn't solve my UBER ANNOYING problem :/
Heres my issue, when I turn my turn signals on my door/rear hatch dummy lights flicker along with my clock (which always resets to 1:00). After a while the dummy lights start to "click" so I'm not sure if its a bad relay or not. If I have a door open with my key two clicks forward my clock doesn't light up at all. Also my CD player doesn't work (which it always has worked). My rear defroster switch stay lit up sometimes even if i push it "off", and other times it will not light up at all even when I push it on. Also my door chimes don't work and my dome and map lights don't work at all. I posted on NWP4life and G2IC and members were puzzled and said check fuses and grounds... and two members said replace the whole fuse box. Just wondering what anyone thinks. It is very frustrating so any help is greatly appreciate!!
Jason
Jason
Did I not answer this already, maybe someplace else, [G2IC]?
Pull the HU, [CD] and check for 12V+ constant at the radio harness, [yellow lead on aftermarket HU and white/blue in stock radio harness] this will be fuse 14-14A, [hot at all times] in under dash fuse box. 94
