b16 running/idling rough.
Old Dec 7, 2011 | 03:07 PM
91efbluehatch's Avatar
Default b16 running/idling rough.
my b16 was running perfectly fine about three days ago.
i ran out of gas in my driveway (lucky me)
next day i went out to crank it, and it was running rough, like on 2 or 3cylinders.
today i did the following
-replaced all four spark plugs
-put 10gals of fuel in it.
started it up.
ran rough again, so i was like "WTF?"
saw a small fuel leak by injectors, so i pulled the rail off, and i replaced #3 injector since the o-ring was jacked up.
installed everything back, cranked up it, same thing....
NOW i finally got it to idle, pulled plug #1, and it got worse. put it back in. pulled plug #2, same result....so i know those two cylinders are firing good.
pulled #3 and #4 plug, and nothing....
plugged em back in no improvement...i also undid the injector clips for #3 and #4 and nothing..
so now im thinking low compression in those 2 cylinders? how is that possible with it driving perfectly fine even into my driveway??
i checked for CEL codes, and i am throwing TDC sensor code, IACV (seemed to work perfectly fine last week and before this messup) and im also throwing code 17 VSS. which i double checked connection to the cluster and the unit on the trans.
compression test will be done tomorrow
will get back.
any ideas?
Old Dec 7, 2011 | 06:33 PM
Default Re: b16 running/idling rough.
ok so the car has been ran bone dry outta gas at least twice since i have done the swap.
cylinders not getting fuel?
something clogged. if so what?
SmaTTeRLegion
15
Sep 2, 2013 11:28 AM
MagicalMike
Nov 26, 2011 03:23 PM
EvilPinkEye
Sep 1, 2006 10:20 AM
ibanez4string
May 27, 2004 05:39 PM
crxgurlllll
Oct 22, 2002 04:20 PM
