Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
tranny problem
Old Dec 7, 2011 | 05:51 AM
CE-CE's Avatar
Default tranny problem
So I just swaped the motor in a 2003 honda civic auto. car shifted fine before the motor was changed, but now when I pull away from a dead stop the tranny seems to be stuck in high gear. If I put the car into 1 gear and manual shift the car it is fine.
the plugs are all in the tranny and the fluid is full
any help woukld be great
Old Dec 8, 2011 | 02:40 AM
It Wasn't Me's Avatar
Default Re: tranny problem
Is the "D" indicator flashing?
MIL on?
Have you checked for any stored codes? Sometimes the ECU will be holding onto them without illuminating the MIL.
Something may just be out of adjustment. Have you gone back over your work?
Old Dec 9, 2011 | 09:54 AM
igotthaspirit's Avatar
No kidding. You obviously did something wrong. Check all your electrical connections. Some of them can interchange.
Old Dec 9, 2011 | 11:13 AM
JEBirdman's Avatar
Yeah, go step by step and check every single connection... It sucks when you spend all that time and it doesn't work right. Transmissions can be very complex though too. Good luck.
brandonm718
Apr 21, 2017 06:09 AM
Rancidracer86
Dec 18, 2008 06:57 AM
B16Jacques
Sep 17, 2006 09:26 PM
professorman
Feb 14, 2003 08:10 AM
yellowbuffalo
Jun 25, 2002 09:14 AM
