Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ES1 ex Auto acting up
Old Dec 7, 2011 | 05:38 AM
DjJohnnyStorm90's Avatar
Icon3 ES1 ex Auto acting up
Whats Going on World! I have a few questions....
Sorry for the Mutli-questions......
1.At times i start my car and it drops bellow 1000rmps and seems like its gonna die out or when i drive, once in a while it seems to stall out!
2.When i drive it feels like when the gears shift its a sudden pause then picks up or jerks a little.
3. i prob need a wheel alignment and tire balance but after going 60mph-80pmh i let go of the gas peddle and i hear a knocking sound. It only happens between 60-80pmh.
Any Help or Tips on these situations ?
Old Dec 7, 2011 | 08:46 AM
Default Re: ES1 ex Auto acting up
Help any1
Old Dec 7, 2011 | 02:22 PM
01_civic's Avatar
2) seems like a problem with a tranny. I'm guessing its starting to slip. Have you changed out the tranny fluid yet? If not, do so. How many miles u have?
Old Dec 7, 2011 | 02:28 PM
It Wasn't Me's Avatar
How many miles are on the car? What year is it?
When is the last time you serviced the transmission?
Have you done any other maintenance? What, and when?
Have you inspected any of the mounts and bushings? (transmission, motor, LCA, sway bar, etc etc. Everything.)
Is the MIL on?
Does the "D" indicator flash?
1. Sounds like it's time for a tune-up.
2. Transmission. Check level and condition of fluid. Flush and fill if necessary. If the fluid is full and new(ish) - it's probably time for a rebuild/replacement.
3. Could be a number of things. Start simple. Inspect bushings, mounts, suspension components etc. for cracks, breaks, loose or missing parts, etc.
Old Dec 7, 2011 | 04:55 PM
i got 180,000+ it recently started to act up.. 2001 ES1 ex. I did a tune up to the car and it was still running good.. I gotta try the tranny fluid...I have done simple maintenance to keep the car going...
del Slo SiR
10
Sep 18, 2008 08:15 PM
janz3n
Nov 10, 2007 12:08 PM
KillerElfboy
Jun 30, 2006 08:58 AM
jabenne
Nov 20, 2003 09:18 AM
Mase
Jul 2, 2002 10:07 AM
