97 accord ex 4cyl missing intermittently
Old Dec 7, 2011 | 04:35 AM
bemenaker's Avatar
Default 97 accord ex 4cyl missing intermittently
My accord with 230K miles on it started to miss on me yesterday. It was a complete miss, but it was pretty solid miss under load, and lower RPMs. Last night I changed the cap, rotor, plugs. This seemed to have helped, but it isn't completely gone. I still have a miss, but it is much more intermittent now, it was almost continuous at first.
I'm not really sure what to do next, I was thinking either the coil or the ignition control module. But, after reading some on here, I'm also thinking I need to check the egr valve.
Thoughts?
Old Dec 7, 2011 | 03:06 PM
roncourville's Avatar
Default Re: 97 accord ex 4cyl missing intermittently
Could be any of them. EGR could be stuck open at times if it is intermittent I would take your ICM (Igniter) to auto zone they can test them there. Also check coil for resistance. Primary should be in the .5 to 2 ohm range and secondary should be in the 30 35 kila ohms.
Does the miss happen at cruising speeds?
rwkgramps11
Mar 19, 2023 12:44 PM
mindslayer84
Jan 4, 2016 07:11 PM
Mephistopheles
Aug 16, 2010 10:07 AM
