EF suspension on EG, disadvantage?
Old Dec 6, 2011 | 07:54 PM
s13hero's Avatar
Default EF suspension on EG, disadvantage?
I've read a lot of threads asking about EF suspensions on EGs, and if its possible, from what I've gathered the rear will swap fine, but front requires EF forks, now my questions is, is there a disadvantage to doing this swap? I can get a set of Koni yellows for super cheap but they are for EF.
Cross-posted in suspension as well, but I thought maybe there would be more first hand experience here.
Old Dec 6, 2011 | 07:59 PM
owneyboy's Avatar
Default Re: EF suspension on EG, disadvantage?
you benifit.. the shock body is about 1inch lower than eg . but same height in over all so you gain 1inch of shock travel.
Old Dec 6, 2011 | 08:16 PM
s13hero's Avatar
Ok, thanks, I was worried the car might be too low, as I had read that happened to some people when they swapped, but since they are adjustable, I could just raise it up correct?
Old Dec 6, 2011 | 08:30 PM
owneyboy's Avatar
hard to explain. konis have adjustable perchs where you can place coilovers higher or lower on shock body. or adjust he coilovers yes would be better. i would also recommend extended top hats if your car is super low
Old Dec 6, 2011 | 08:35 PM
s13hero's Avatar
Ok thanks again for the help, I'm going to pick up the struts then take a look at them. The car isn't super low now and I'm trying to keep it that way, I'm just pretty new to suspension tuning, luckily the car isn't being driven right now though so I have time to learn and adjust the setup.
Old Dec 7, 2011 | 11:00 AM
s13hero's Avatar
Anyone else have any input or experience? pictures? I've seen a few threads with people saying it will be lower, but ride better. Although, one post I found said since the EF shocks are 1.3" shorter than EG, putting, for instance, a 1 inch lowering spring, you would be lowered 2.3" but ride like you were only lowered 1 inch, is this true? Also just putting stock EF suspension on an EG, would make the front lower than the rear would it not?
Old Dec 7, 2011 | 12:33 PM
anothersickhatch's Avatar
In my experience, I am against using suspension parts that are designed for a different car. The ride height may look decent and it will most likely handle better than stock suspension, but not nearly as well as a set that was made for your car. I used several sets of springs for my 92 civic from other models and then bought a set of Tein coilovers. The difference was night and day.
Old Dec 7, 2011 | 03:12 PM
s13hero's Avatar
What about using EG springs on the EF shocks? Also, comparing EG to EG, would it be worth getting new springs that were 375 in the front, currently on the EG I think I have 275.
Old Dec 8, 2011 | 09:54 AM
I would say yes. You can buy a decent spring/shock set-up for relatively cheap and it will be worth it in the long run.
4cylJDMcrazE
Suspension & Brakes
May 22, 2013 10:27 PM
s13hero
Suspension & Brakes
17
Dec 13, 2011 05:57 PM
JDM_guru
10
Mar 11, 2009 01:44 PM
Ion22
Suspension & Brakes
Aug 11, 2006 08:39 AM
JDMef_typeR
Sep 22, 2004 12:00 PM
