6th Gen Bumpers
Does anyone know if the 01 sedan and coupe bumpers are interchangeable w/o having to drill new holes and what other parts are necessary to change over. Plus a 00 sedan bumper to an 01? Any help would be apprecited. Thanks
Thanks for the replies guys, Don't mean to doubt your expertise, but is this for sure, because the thing is that I've checked out a couple of different sites and couple of diff people, no one's done it or said that they've attempted to do it. Som say yes, but the hood is too long, some say yes with modification but then you guys are the first to say no for sure.
Dude..just look at the 01-02's grille and 98-00 's grill..it's different shape!!
The screws under the bumper is not located at the same place too.
It's like putting a sedan bumper to coupe.
you can put the FRONT coupe bumper on a sedan no problem. the hood will have to be swapped to a coupe hood as well or else you will have about an inch gap between the hood and the bumper. never seen a sedan bumper on a coupe, but I guess it would work if you swapped the hood as well. Both times Ive seen this done the front bumper was from a 98-00 coupe, since they have the removeable grill nstead of the molded in one from the 01-02. I'm not 100% certain about the bolt holes. the main ones are the same, but there are a few slight differences. you wold have to drill a few holes, but none would be visible.
journeyforce
Mar 7, 2009 05:06 PM
cantaffordaccord
Jul 25, 2006 08:49 AM
singlecam screamer
14
Jan 31, 2003 04:16 PM
