D16Y7 help, strange rattling when accelerating.
Old Dec 6, 2011 | 06:27 PM
GDLafferty's Avatar
Default D16Y7 help, strange rattling when accelerating.
Hey all, I've got a 97 Dx hatch, 86k miles on it. My timing belt was replaced at 77k.
I've noticed that when I accelerate, or if I rev it in neutral, I get this strange rattling noise coming from somewhere under the hood, as if something is loose. No CEL's, nothing else, just this. If anyone could help me with pin pointing what it could be, that'd be great. Thanks!
Old Dec 6, 2011 | 07:23 PM
redm3turbo's Avatar
Default Re: D16Y7 help, strange rattling when accelerating.
you check your heat sheilds?
Old Dec 6, 2011 | 08:39 PM
Wrona's Avatar
its something within your tranny since yours is an automatic i had thesame thing happen to me i replaced my tranny fluid all of it and it stopped doing it
Old Dec 6, 2011 | 08:57 PM
seanbev24's Avatar
It could be anything. You at least need to tell us which area the noise is coming from for us to be helpful. An automotive stethoscope really helps to pinpoint noises. You can get one at Sears for cheap. If you can't afford that, put the handle of a long screwdriver to your ear and touch the tip to different areas of the engine/tranny/etc.
But yes, loose heat shields are a popular cause and I've heard plenty of rattles coming from trannies. When people complain about engine bay noises, the most popular area tends to be the timing side of the engine.
Old Dec 7, 2011 | 05:34 AM
cpek4's Avatar
you know what that means... time for a swap!
Old Dec 7, 2011 | 05:35 AM
GDLafferty's Avatar
Not yet, I'll do that here in a few when I'm up and going.
So you're saing I should flush my tranny fluid and replace all of it?
Old Dec 7, 2011 | 08:42 AM
seanbev24's Avatar
Replace the whole tranny while you're at it. Or... go figure out where the noise is actually coming from.
Old Dec 7, 2011 | 08:44 AM
alston3ptswish's Avatar
Most likely a heat shield. I eventually ripped off every damn heat sheild on my Sol because every1 eventually started making rattle noises over time.
Old Dec 7, 2011 | 10:11 AM
milkwasabadidea's Avatar
check the heat shield on the exhaust manitold.... then check the heat shield on the catalytic converter which is part of the manifold.. then check the heat shields on the down pipe porton of the manifold
Old Dec 7, 2011 | 10:59 AM
GDLafferty's Avatar
to tranny swap...
to lack of funds...
I'll do this when the car cools down. I just drove back from campus (30 minute drive.)
P.S. Where in PA are you located?
I like your thinking
tur3oDC4
Nov 25, 2004 11:05 AM
EK45VTi
Oct 12, 2004 10:58 AM
roydogg
Sep 15, 2004 10:18 AM
jgl3
Acura TL, RL & ZDX
May 10, 2004 12:28 AM
HXvtec
10
Oct 16, 2003 04:39 PM
