Engine stuck after installing transmission
Old Dec 6, 2011 | 09:08 AM
JH4DB858's Avatar
Default Engine stuck after installing transmission
After swapping in new transmission on my 1997 2.2 cl, I go to spin the crank its stuck. I look through the dusk cover looks like torque convertor in forcing the flywheel to hit the block. I loosing the bolts to the transmission now the crank moves freely. Can someone tell me what I did wrong?
Old Dec 6, 2011 | 12:08 PM
92civlude's Avatar
Default Re: Engine stuck after installing transmission
The converter wasnt set all the way on the shaft.
Old Dec 6, 2011 | 02:20 PM
oneprblmcat's Avatar
What he said. But more specifically, the converter is notched to engage the pump where it slides into the transmission. The converter can be on the shaft but not seated all the way into the pump thereby pushing on the flexplate when you mount the transmission to the engine.
Angel4768
Aug 26, 2010 09:52 AM
mtdempsey2
Dec 9, 2008 08:55 AM
88whitehatchidaho
Mar 3, 2006 12:08 PM
VTC_CiViC
Jun 8, 2002 09:04 PM
VTC_CiViC
Jun 8, 2002 04:53 PM
