new clutch started slipping
Old Dec 5, 2011 | 08:29 PM
Rickdogg's Avatar
Icon3 new clutch started slipping
I put a new oem exeddy clutch and flywheel in about 1500miles ago now it started slipping when I hit the throttle past half way but all my gears work fine and takes off fine if I give it gas slow
Old Dec 5, 2011 | 08:32 PM
91efbluehatch's Avatar
Default Re: new clutch started slipping
i'd take it off and visually inspect it.
sounds like something might have been installed wrong, or you've been getting on it.
but when did OEM classify as an Exedy clutch?
Old Dec 5, 2011 | 10:34 PM
rd91sib18c5r's Avatar
Cable is to tight. If not take it apart and inspect.
Old Dec 6, 2011 | 05:00 AM
crvtectim's Avatar
Adjust clutch cable first, then get back to us.
Old Dec 6, 2011 | 05:19 AM
90civic-ZC's Avatar
If you go to Bap Geon theIR OEM replacement for Honda is Exedy. I would do as the others suggested and adjust your clutch cable. Did you install the clutch in reverse?
Old Dec 6, 2011 | 01:20 PM
apexi_rsx's Avatar
you can only install the clutch one way. i know when my xtd was new it slipped alil until it was worn in then stopped slipping. as others said the cable may be too tight loosen it up some. this is why hydro clutches are so superior because they dont need adjusted.
Old Dec 7, 2011 | 12:41 AM
Rickdogg's Avatar
I loosened the clutch cable up some seems like its grabing better haven't drove it that much yet only about 10 mins
Old Dec 7, 2011 | 01:29 AM
jdm_d15b_vtec's Avatar
id give it a good test pull hand brake put it in 5th rev it to about 5 grand and dump it if it stalls right then and there its not slipping anymore
danno33
12
Sep 30, 2012 08:46 PM
danno33
Jul 14, 2009 07:45 AM
utn
May 26, 2007 09:52 AM
djsire
Sep 7, 2005 04:14 PM
headrec*
Jun 24, 2005 09:59 AM
