ls crx studder
Old Dec 5, 2011 | 11:09 AM
delsol92's Avatar
Default ls crx studder
i have a crx with a b18a1 cable tranny stage 4 clutch
my issue is a studdering problem
the car idles perfectly seems to run good
1st gear is fine as well as 4th and 5th
2 gear at 5000 rpm it starts to studder
and i shift to third and 3rd at 3000 rpm it studders
other than those 2 gear the car is fine
the tps at closed throttle reads 5, 0, and .37 on the signal wire
open throttle 5, 0, 4.45 on signal
can figure out what it is
i do not have an o2 sensor by the way
could that be my problem
Old Dec 21, 2011 | 01:15 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: ls crx studder
yes, not having an O2 sensor is probably 99% likely your problem. fix that.
fuzzysig
Acura TSX
17
Oct 11, 2017 05:05 PM
raney
Apr 4, 2009 01:05 PM
gmacarize
Jul 3, 2008 04:11 AM
g2tegsown
Aug 12, 2005 11:43 PM
4drlsvtec
Sep 5, 2002 04:57 AM
