oil pressure switch question
Old Dec 5, 2011 | 07:31 AM
mutiny93's Avatar
Default oil pressure switch question
I found out where my oil leak is coming from and it seems to be the oil pressure switch. I was told that I could put some tephlon tape on the threads, but the only thing is I think it would get to hot for the tape. so my question is should I just replace it and spend the few extra bucks on it or should I use the tape? i just want to do what will last the longest
Old Dec 5, 2011 | 07:40 AM
notsolfast's Avatar
Default Re: oil pressure switch question
replacing it will last the longest. i wouldn't really feel safe using teflon tape for something that important.
Old Dec 5, 2011 | 08:04 AM
mutiny93's Avatar
thanks I was thinking the same just wanted at least one other persons input. then with the car off and after it has been sitting I should be able to replace that without oil draining out right?
Old Dec 5, 2011 | 08:15 AM
10psiLsEf2's Avatar
go to ace hardware or your local home depot and pick up a roll of YELLOW teflon.
this yellow teflon is made to withstand heat,oil,petroleum.....etc
good luck.
Old Dec 5, 2011 | 11:08 AM
djkurious's Avatar
Buy a new switch and the threads already have the tape on it.
10 buxs.
Old Dec 8, 2011 | 07:39 AM
mutiny93's Avatar
thanks guys sounds good and I wasn't worried about the price because i know the switch was only a few bucks. I just wanted to know what would last longer and you guys answered that for me. Thanks again
Old Dec 8, 2011 | 10:19 AM
mr500cm's Avatar
If its leaking and its old its not leaking from the threads so all the tape in the world won't fix it. Its leaking because the rubber diaphram inside broke, fix it its easier than blowing an engine.
Old Dec 8, 2011 | 11:32 AM
StreetsideStig's Avatar
I agree. Just replace the part. You will lose some oil in the process, though, so have an oil pan ready.
Old Dec 8, 2011 | 02:25 PM
19Accord97's Avatar
I replaced mine 2 months ago. costs like 10-15 bucks.
Old Dec 9, 2011 | 07:25 PM
nus_dogg's Avatar
Even some new ones won't have thread sealer on them. Just be sure to put thread sealer/teflon tape on it before you put the new one in.
Old Dec 9, 2011 | 07:54 PM
10psiLsEf2's Avatar
EXACTLY
like i said get yellow tefflon at your local hardware store. or home depot.
the white teflon deteriorates with petroleum and oil
DA_9
Jan 8, 2008 10:16 AM
Gsir8
Jun 29, 2007 04:46 AM
RaCk
Jan 4, 2006 12:28 PM
civbeater90
Jul 16, 2002 06:27 PM
