949 Wheel fitment
Old Dec 5, 2011 | 12:06 AM
87mugenprocr-x's Avatar
Default 949 Wheel fitment
I'm looking to purchase some 15x9 +36 949 6UL's for my 94 4dr Civic, but I'm not sure about fitment. I've heard others say they may hit the trailing arms in the rear. I am personally concerned if they will fit in the fenders(I'm planning to cut the fender lips but would prefer not to pull). Anybody with experience on this setup? The tire will be a 225/45/15 Hankook.
Julian
Old Dec 5, 2011 | 05:21 AM
toyomatt84's Avatar
Sanji
Default Re: 949 Wheel fitment
As long as you roll the front fenders and cut the rear quarter panels, you should be able to clear that setup without using too much negative camber.
Old Dec 6, 2011 | 03:35 PM
doc@tirerack's Avatar
225/45R15 would be a stretch on a 9" wide wheel, plus as mentioned above will need fender and probably suspension mods as well......
Old Dec 7, 2011 | 12:56 AM
Thanks for the input. Any one else try this or a similar setup on an EG?
Julian
Old Feb 7, 2012 | 06:55 PM
Ryan's_Eg6's Avatar
I got that set up on my hatch. They do hit in a couple places front and rear and the tailing are will hit. what i had to do is roll ur fenders,extended wheel studs, wheel spacers front and rear and i am running a 205/50/ and plus if u don't already have your adjustments for camber rear toe and ext.... will make it easier for u to make them fit. also i didn't have to cut nothing
Old Feb 7, 2012 | 06:57 PM
ToTriggerHappy's Avatar
run a normal sized wheel and you wont have any problems.
Old Feb 7, 2012 | 08:52 PM
hatmanafro's Avatar
pawrty pewpurr
Old Feb 7, 2012 | 09:25 PM
guess_who's Avatar
Why not run the 15x8?
Old Feb 9, 2012 | 06:51 PM
Ryan's_Eg6's Avatar
ya i guess u could, but i don't see the fun in that. I am all about trying to be different from the next but i know that is hard as hell but doesn't hurt to try....... but that's me, my next thing is trying to fit 15x10. First ill see how low i get on these
CWBETB
Apr 25, 2012 02:47 PM
meric0786
Jul 10, 2011 11:16 AM
95B18BTurbo
Feb 24, 2011 06:10 AM
jdmztrane
Jun 28, 2008 09:51 AM
robotnik
Dec 4, 2005 04:42 PM
