helpp!!!! motor choke on > 30% throttle
tried searching but the search button s.u.x.
anyways, im having a issue with my teg. i recently just swap a stock gsr swap into my teg and it will choke (wont rev any higher) and died out everytime you go more than 30% throttle (this is while in neutral and driving). but if you baby the throttle (less than 30% throttle) the motor will rev up fine. i have tried different map sensor, ecu, injectors, fuel rail, spark plugs, spark plug wires, and distributor WITH KNOWN working one. i am out of clues as what is wrong with the motor. the compression is 180 psi on all 4 cylinder. timing is dead on. the gsr swap was running perfectly fine before it was taken out.
the only thing i had to change was unwire the resistor box as i had a resistor box on the previous motor before and i chop off the wires for the abs system. other than that nothing has been touch.
also, only mod on the car are Intake/Exhaust/Hy-tech header.
any suggestions are greatly appreciated.
Do you know how to check the Throttle Position Sensor for its reference signal, and for proper output?
Is the TPS connected correctly to the ECU?
Im having the same problem also in my lsvtec but I was thinking its a bad dizzy but now that you said you have switched all thoese things and still no luck im worryed about mine now. I hope mine is just a bad dizzy lol damn
already did. that was the first thing i did. plugs arent the issue. i am out of ideas. i'm using a stock gsr ecu and a chipped p28 ecu. both acts the same
scrEaMO Kyle
Jan 25, 2005 07:55 AM
