Help!!! obd0 wire harness
you need to clear up your post
if your trying to put a si harness in your std/dx it wont work
if your trying to run a obd1 dizzy in your 88-91 civic it wont work either without a jumper
rywire sells jumpers and im sure some one here can rig you one up
clear **** up so we know what the fukc your talking about
all i can gather from your rambling is:
-i have an obd0 si engine harness with obd1 distributor plugs
-why wont this harness fit my crx
answer the following:
1. what model crx do you have? DX? Si? or HF?
2. what are you trying to accomplish by installing this modified harness?
This morning, I already swap d16z6 motor from eg to 1990 my crx dx. I bought wires harness from ef civic si harness OBD1. But, it is not fit wires harness to my stock OBD0 wires. Do you know why ?? You say it wont work. Reason why?? What it need to do??
First off there is no such thing as "EF CIVIC SI OBD1." since your car is a dx model you need to do a dx to si conversion. Then to properly run your car you would need to do an obd1 conversion as well. The reason your new harness doesn't plug in is because both the Si and dx have completely different engine harnesses.
ok well if you mean you have an 0bd0 ef civic si harness it wont work with a obd1 dizzy and the shock tower plugs are different as well.
if it is infact the obd0 si harness ill buy it off you lol. seriously thought if you cant use it text or call me 414 397 060
DPFI-MPFI conversion
OBD0-OBD1 conversion
Harness needs to be from CRX DX. You must modify CRX DX harness.
Good luck.
the reason nobody is explaining why it wont work is because noone knows what the hell you are talking about
