H22A Crankshaft Pulley
I've been trying to take the crankshaft pulley off of the H22A but it wont budge. I heard that because it is a japanese engine everything is backwards, so instead of left=loose and right=tight its right=loose and left=tight. Is this true?
When I removed mine I used a powerbuilt crank pulley tool and worked fine.
http://www.amazon.com/Powerbuilt-648.../dp/B0000TMLWQ
It should be lefty loosey. Righty Titey.
Yeah Im using the same exact thing except when I was tryinh to take off the bolt it destroyed that peice. Ill put a pic up to show. I even welded it to a bbreaker bar to make sure it wouldnt move.
I went and tried today. I sprayed some pb blaster on it but I couldnt get a my generator to turn on so I couldnt use my impact gun. I just used my breaker bar but I still wasnt able to get it off.
My tool is a Snap On brand. Im not sure what the material of yours is made from not that it matters in this case but I did notice that the Snap On's arm is shorter which would make it less likely to bend like yours did.
You can use a gun but in your case you might have to use a Nitro gun or 3/4. Just hope the head does break off leaving the shank in the crank.
Heres some guys trying to different strokes
http://www.youtube.com/watch?v=7Crid...endscreen&NR=1
http://www.youtube.com/watch?v=0h5vbzdu5K0
DO NOT DO THIS
http://www.youtube.com/watch?v=fgY3-...feature=fvwrel
DO NOT DO THIS
Well I went to 3 different shops today and not 1 could take off the bolt. Tomorrow im going to try my luck again. I was told to go to a shop where the might have bigger gun. I hope they can get this bastard off!!!!
i eventually used a piece or angle iron welded to a bolt, and i installed it into the trans and blocked the flywheel.
then i used my 1/2in 19mm socket and ratchet and a 4 foot piece of pvc pipe, and after about 15 mins, it eventually gave way...and i broke the end of the pvc pipe in the process
If you don't have access to heat, the next best thing that works for me is using a good piece of 2x4 to smack the **** outta the breaker bar. Usually 3 or 4 good whacks is enough to break the bolt loose. This is easier with 2 people, one being brave enough to hold the breaker bar while the other goes to bat lol. The problem with using big cheater pipes on your breaker bars is you're not able to apply the hammer action that you get with a bad *** impact gun. You're just applying a bunch of leverage, which can lead to you raping your fender when the bolt finally pops loose.
But i was able to get it off today. I went to a truck shop and they used a 1" impact gun. He said it had to be torqued pretty high cause it didnt come off right away with the 1" impact. Took a little before it gave way..
Thanks for all the help guys!!
