93 LX starting issue
Old Dec 2, 2011 | 06:10 AM
gnnr2's Avatar
Icon6 93 LX starting issue
I've looked through the other threads to make sure no one else had this issue. So here is the background:
Bought my Accord used about 9 months ago with 169k miles. When I bought it, I asked about what services had been done and all the services were up to date. Timing belt was changed at 80k and 160k. Changed the plugs, new battery. She was running great. I now have 173k miles. I've been averaging about 25 MPG in town. Most of my trips are between 5-10 miles.
A couple weeks ago, I drove into work and parked. I was waiting on one of my guys to show up so sat there for a bit. I got a little chilly so started it to turn the heat on. I ran for about 5 minutes, then the engine cut off. It has never stalled on me before. I tried to restart it, but all it would do is crank but not turn over. Looked under the hood, couldn't see anything obvious. Tried again and realized that I couldn't hear the fuel pump working when I turned the key on. Followed the trouble shooting procedures in the Honda Service Manual, checking all fuses (all good), PGM-FI relay (tested good), etc and so replaced the fuel pump, strainer, and fuel filter. Still wouldn't start. I loosened the banjo bolt at the beginning of the fuel rail to make sure I was getting fuel, and it sprayed out when I turned the key on. Tightened it back up and tried to start it again. It started and ran for a little over a minute then died. Tried to restart, nothing. I loosed the service bolt at the end of the fuel rail, to make sure I got fuel there, and it came out. Tried to restart it and it fired up for a second then died, and won't restart.
Basically, I'm at the end of my knowledge/abilites. The only thing left that I can think of is to have it towed into a shop, but trying to fix this on my own to a) save money, and b) take care of my car myself. Any ideas or suggestions will be greatly appreciated.
Old Dec 2, 2011 | 07:07 AM
9t3Akord's Avatar
Default Re: 93 LX starting issue
Try checking the injector resistor and the wiring around it. It could possibly be the dizzy also.
Old Dec 2, 2011 | 07:11 AM
gnnr2's Avatar
I am going to check that, but what are the odds of it going bad the same time the fuel pump goes?
Old Dec 2, 2011 | 09:32 AM
9t3Akord's Avatar
Its very unlikely. You mentioned on your original post that you are getting fuel on the banjo bolt by the fuel rail when you crank the motor thats why I eliminated fuel pump and the main relay.
Old Dec 2, 2011 | 12:14 PM
bdmlilburn's Avatar
remove gas cap and use an air compressor to shoot air through the fuel return line that comes off the fuel pressure regulator(fpr) to make sure its not clogged. also make sure the vacuum supply to the fpr is not clogged or broken.
test the fpr
Old Dec 4, 2011 | 04:30 AM
Lost Again's Avatar
And I would really check for spark.....
Could be something (ICM, coil) getting hot and giving up. When the no start happens, check for 12v at the BLK/YEL wire at the dist. Then check for spark at the plugs (timing light or other means). See if this helps.
http://techauto.awardspace.com/ignition.html
Old Dec 10, 2011 | 09:00 AM
gnnr2's Avatar
Checked for spark at the plug and wasn't getting any. Checked for spark after the coil, didn't get any. Used mulitmeter on coil and found that it was bad. Replaced it and she's running like a champ again. Thanks for the advice.
Old Dec 11, 2011 | 05:30 AM
Lost Again's Avatar
Good to hear. Thanks for updating the thread...
Chobbles
Dec 22, 2014 05:15 AM
GIGgle_Hurtz
Dec 14, 2014 04:48 PM
dylanear
Nov 21, 2012 08:16 PM
jiujitsuhonda
Jul 23, 2012 10:42 AM
xft1ss
Feb 19, 2007 11:08 PM
