Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
HELP em2 01 civic ex
Old Nov 30, 2011 | 11:02 AM
7azhar7's Avatar
Default HELP em2 01 civic ex
My friend drove his car into a puddle having cai in the car. the car took in water into the engine. oil leak what he told me first. The car sat for 5 days. I went to check the car. wanting to fix it hoping it doesnt have hydro lock. has no oil so i fill just a little bit. start the car. it started but the engine started shaking erratically n sounded like miss firing. so i shutted off. the car starts yes. but what could be the problem?
Old Nov 30, 2011 | 12:30 PM
toyomatt84's Avatar
Sanji
Default Re: HELP em2 01 civic ex
Pull the spark plugs out and look in to the combustion chamber with a flashlight. If the engine took in water, my guess is that it hydrolocked and damaged a rod or valve.
Old Nov 30, 2011 | 12:33 PM
7azhar7's Avatar
with hydrolock the car still starts?
Old Nov 30, 2011 | 12:39 PM
toyomatt84's Avatar
Sanji
If it dried out, it could. You let the car sit after the car locked... so who knows if it had a chance to air out. As long as there is fuel and spark, it could fire on 2 or 3 cylinders.
Old Nov 30, 2011 | 01:37 PM
7azhar7's Avatar
Just checked. the sparked plugs were rusted. the water must of dried up. the car starts np. just engine shakes like crazy and idal rough.
Old Nov 30, 2011 | 05:17 PM
toyomatt84's Avatar
Sanji
Did you check inside the combustion chamber for damage? Look at the piston tops for damage from impact.
Old Dec 1, 2011 | 08:16 AM
7azhar7's Avatar
Is there a guide. I found one for valve clearance. Could take it off but might need torque spec to put back on
Old Dec 1, 2011 | 04:03 PM
toyomatt84's Avatar
Sanji
Well, you should see damage without needing to remove the head.
mikael
Jan 10, 2005 05:56 PM
fastludeh22
Jun 3, 2003 03:45 PM
white Si
May 25, 2003 05:32 PM
thaiphob
Feb 14, 2003 08:34 AM
Muad'Dib
Jun 15, 2001 03:04 PM
