1992 Accord Bent Exhaust Valve
Old Nov 29, 2011 | 02:54 PM
leefybeaver's Avatar
Default 1992 Accord Bent Exhaust Valve
Hi all, new to the Honda forum...new to fixing Honda's but not an entire newb to the internal combustion engine. This old car was given to me and has nearly 360 000 km on it so I won't be too sad if I have to invest a small amount of money to fix the valves.
Anyway to make a long story short I'm pretty sure I have some bent exhaust valves as a result of an improperly installed rocker arm assembly (MY BAD) after replacing the spark plug tube seals. The reason for me to believe that valve(s) are bent is they tend to hang up after being depressed. I can loosen it just by tapping the spring with a screw driver and it pops back to the closed position.
1. Can I replace JUST THE VALVE? I figure I need another 6-8 months of driving out of this thing then it can die forever...again. So if I can jsut do the valve I would be happy.
2. Do I need any other special tools. I know I needed a special valve spring compressor for my 4.6L mustang heads, but these look much simpler...small block Chevy simple!
I appreciate any helpful hints.
Thanks
DL
Old Nov 29, 2011 | 07:01 PM
chikin pickle's Avatar
Default Re: 1992 Accord Bent Exhaust Valve
To replace the valves you need to pull the head. Lot's of work, and it is also possible that the valve guides have been damaged.
Really, if you want 6-8 months out of the car don't waste your time. Just drive it with the bent valves hondas are pretty tough. I wouldn't even worry about it.
Old Nov 29, 2011 | 09:39 PM
holmesnmanny's Avatar
Is it only the valve seals that can be replaced with a special tool while the head is still on the car ?
Old Nov 30, 2011 | 08:35 AM
StreetsideStig's Avatar
I made exactly the same mistake on my '90 coupe. It meant the end of the car. Replacing the head might be cheaper/easier than fixing the valve.
blackeg
Feb 16, 2012 07:34 AM
thewrai6th
Jan 20, 2010 05:00 PM
Robotoyaki
Jan 1, 2010 02:10 PM
RedRacerCivic
Jul 11, 2002 12:19 AM
