Any recommendations of what kind of spacers I should get ?
I want to know some specific things about spacers, if any has and recommendations for how thick? I should get them.. I have a 97 civic hatch with some bbs's and just want it to look good&flush
You're going to need to provide far more information then that. What is the size and offset of the wheels you have, are you running any camber, has anything been done to the car to increase wheel/tire clearance, etc.... On stock lug studs, the largest non-studded spacer you can safely run will be 5mm thick.
Front and rear camber kits, fenders rolled, stock lug studs, I'll probably start off at a 5mm to be safe like you said and see how it turns out on the meanwhile ill be learning more about offsets thanks for replying & also my rim size is 15" my offset, that I would have to double check tmmrw!
Front and rear camber kits, fenders rolled, stock lug studs, I'll probably start off at a 5mm to be safe like you said and see how it turns out on the meanwhile ill be learning more about offsets�� thanks for replying & also my rim size is 15" my offset, that I would have to double check tmmrw!
It's either 6j or 8j x15 h2? Goin to double check on inside rim cause outside has been painted therefore I can't really make out that number!
If its 8j, then you're looking at about +30 or so, before you start running in to improper tire sizing and clearance issues.
ek_david
10
Apr 14, 2004 09:25 AM
