Those with a 4th gen and hondata.....
I have a p74 teg ecu i'm running with my hondata.....how did you guys mount back the ecu since the teg's ecu holes don't line up with our ecu mounting holes? also where did you mount your hondata box. Thanks.
Hey,
I just put one bolt back on, and then that foot panal pushes down on the ecu. OS it doesn't move at all. I think I put the bottom right one on thats it. I mounted it on the passenger side foot panal.
Josh
Josh
I used a longer 10mm bolt to bolt the ecu down to one of the stock ecu holes, then i took a dremel and cut the cover panel post that hits the p74, then i put the cover on. i have my blue box in the glove box, i just notched out the top of the glove box so that it closes. Thats a good location posted above, but i just wanted everything out of the way so a passenger doesnt accidentally bump it.
[Modified by GudeH23a, 11:53 PM 10/7/2002]
You could swap the P74 internals into your factory P14 case. It'd bolt right in then.
All you have to do is unscrew a few screws. It's very easy. I'm about 99% sure that the P74 and P14 circuit boards have the same hole alignment and are the same size.
i never even thought of this... im gonna try this out tomorrow
I know the p74 ecu case is a lot longer then the p14 is though... ill post up info on this tomorrow afternoon.
ElectronMan
Jul 15, 2002 02:02 PM
