Replacing middle door moldings ?
Old Nov 29, 2011 | 12:02 PM
Rob.'s Avatar
Icon2 Replacing door protector moldings ?
I ordered brand new door protector moldings for my 90 Crx Si.
I'm just wondering how to remove the old moldings.
Once this nut comes off, is it easy to remove the rest ?
Old Nov 29, 2011 | 12:24 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Replacing middle door moldings ?
It's held in place by clips along the length of the door. I've found that if you tap the molding with a mallet towards the front of the car, it will slide off of the remaining clips BUT this only holds true if they have never been tampered with. Other than that, there's a specific tool you can buy/use OR you can use a couple of flathead screwdrivers to "pinch" the clips out of their respective holes. If you have never done this though, be very careful because you can slip and scratch your paint fairly easily. Did your new moldings come with new hardware or do you have to reuse the existing clips?
Old Nov 29, 2011 | 06:37 PM
my91tealhb's Avatar
I read somewhere to use a couple of putty knives and you have to squeeze the clips from the top and bottom to get them out. I would use some blue masking tape on the top and bottom to prevent scratches. Let me us know how it goes cause I need to do mine as well.
Old Nov 29, 2011 | 11:40 PM
Nooch's Avatar
Where did you order some from? PM me please as I don't check back often enough due to my forgetfulness.
Old Nov 30, 2011 | 12:05 AM
gettin_there's Avatar
Couldn't you get to them if you took the door panel off
Old Nov 30, 2011 | 01:09 AM
91efbluehatch's Avatar
its too much of a pain in the ***
Old Nov 30, 2011 | 03:39 AM
James89DX's Avatar
How do you figure? In the world of interior door panels, EF panels are one of the easiest I've ever taken off. A few screws and you're off in literally a minute or two.
I replaced those same moldings with OEM ones (Nooch - purchased easily straight from my local Honda dealer) and did it from the backside through the door panel by squeezing the clips out.
Old Nov 30, 2011 | 09:27 AM
gnxpro24's Avatar
its not quite as simple with door mounted seatbelts
Old Nov 30, 2011 | 10:08 AM
290allen's Avatar
if done this 4 times now and everytime i have gone through the back with or without door mounted belts. you can remove everything inside the door in less than 20 min. pull this window and remove the belt system and they are all easily exposed.
Old Nov 30, 2011 | 06:41 PM
Hfd_Ed6's Avatar
its quite simple really
start by removing the 10 mil nut for the rear then carefully bend out the molding from the door and push slightly down to release the bottom of the first clip, and then lift up to release the top. repeat for the rest of the clips. lastly the front clip just slide the molding forward and it'll come undone. then clean the dirt and replace or repair the molding.
your kinda just bending the bottom channel of the molding to release the clips from it. done it a few times with my 90' hatch. as i keep repainting my car. guess ill take pics next time.
Old Nov 30, 2011 | 06:46 PM
Rob.'s Avatar
This method, the clips dont come out from the door ?
I have bought a new molding so I dont need the old clips.
Old Nov 30, 2011 | 07:19 PM
Hfd_Ed6's Avatar
just turn the white clips sideways to take them out. the front clip can be pushed through and taken out after on or remove the door panel and look in towards the door prop the inner door support bar. it'll be sitting on it
Old Dec 1, 2011 | 04:44 PM
Rob.'s Avatar
Picked up the side protector moldings today..
I think I will wait and install them in spring time.
Old Dec 1, 2011 | 08:16 PM
vtecn8ive's Avatar
I've done it from the inside of the door before, it was a pain in the *** (as stated). You really have to contort your arms to get to one or two of them.
I've read about using the putty knife too, would try that next time.
alex1321
12
Jan 25, 2013 08:59 PM
y2kferari
Oct 10, 2008 10:19 PM
Integra21
Jun 23, 2003 06:31 PM
CivicBoi
Feb 25, 2003 01:28 PM
Rob!
May 31, 2002 06:16 AM
